Re: Machine Authentication Fail
They would have to visit everyone's computer to make sure it is configured right.  If the computer is not configured using an image or group policy, anybody can delete or change the settings and break things...  I am not aware of any other way you can fix everyone's computer without touching them.
They should seriously look into group policy.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Occasional Contributor I
thanks...
i'll try to push them to create the GPO tomorrow morning, so the GPO will update all client ASAP.
some little note again..i'm able to connect some Win 7 user by changing the Authentication Mode to User or Computer Auth...but this is not happen on Win 8 user. they keep Limited when i change the Authentication Mode. even when the IP is changed to their assigned VLAN. Event viewer said all granted(User and Machine). still figure it out whether this problem comes from NPS or from Win 8.
thanks anyway..i'll get back here soon after GPO Pushed to clients.
