Onguard and Cisco VPN with 2 factor autentication
  • 1.  Onguard and Cisco VPN with 2 factor autentication
    Posted Mar 04, 2019 12:34 PM
    Is it possible to integrate Onguard with an already working Cisco vpn with 2-factor authentication like VIP Access from Symantec?
  • 2.  RE: Onguard and Cisco VPN with 2 factor autentication
    Posted Mar 04, 2019 12:56 PM
    OnGuard is a health agent. You generally wouldn’t use MFA with it.
  • 3.  RE: Onguard and Cisco VPN with 2 factor autentication
    Posted Mar 04, 2019 01:09 PM
    Ok, thanks.
    The question is because a client has that environment already (without onguard) wanted to know if  he would be able to do 2-factor and healt checks to the VPN connections.
    Just to make sure. ¿It won't work or it's not a way to use onguard?
  • 4.  RE: Onguard and Cisco VPN with 2 factor autentication
    Posted Mar 04, 2019 01:14 PM
    You would do it with the VPN connection. OnGuard runs in an overlay fashion.
  • 5.  RE: Onguard and Cisco VPN with 2 factor autentication
    Posted Mar 24, 2019 08:45 PM
    I'd try to sell it that way to the client and see how it goes but right now the project has been put on hold. Thanks
  • 6.  RE: Onguard and Cisco VPN with 2 factor autentication
    Posted Mar 23, 2019 05:51 AM
    Then you are going to have to clarify your VPN setup, client and server side. I was not under the impression you were using the windows VPN client or had any control over the VPN configuration. If you do have control of both, then it's just figuring out where to change the settings, then you won't need to mess with adding any local routes on your workstation. Im using VeePN this product good integration with your Onguard.
  • 7.  RE: Onguard and Cisco VPN with 2 factor autentication
    Posted Mar 24, 2019 08:48 PM
    rockcetman77, normal setup: The cisco vpn client connects to the Cisco VPN Concentrator and does a MFA before being given access to the network. I don't know what you mean about adding routes in the workstation since there is no need for that.
    Are you using the VeePN with MFA and Onguard or just 1 step authentication?
