show ip dhcp database
DHCP enabled
# split
subnet 172.32.0.0 netmask 255.255.240.0 {
default-lease-time 14400;
max-lease-time 14400;
option vendor-class-identifier "ArubaAP";
option vendor-encapsulated-options "x.x.x.x";
option routers 172.32.0.1;
range 172.32.0.21 172.32.15.254;
authoritative;
show ip interface brief
Interface IP Address / IP Netmask Admin Protocol
vlan 32 172.32.0.1 / 255.255.240.0 up up none (none)
show ip access-list vbn-guest-control
ip access-list session vbn-guest-control
vbn-guest-control
Priority Source Destination Service Application Action TimeRange Log Expired Queue TOS 8021P Blacklist Mirror DisScan ClassifyMedia IPv4/6 Contract
1 user any udp 68 deny Low 4
2 any any svc-dhcp permit Low 4
3 any any svc-dns permit Low 4
4 any any svc-icmp permit Low 4
show ip access-list vbn-guest-captiveportal
ip access-list session vbn-guest-captiveportal
1 user controller svc-https dst-nat 8081 Low 4
2 user any svc-http dst-nat 8080 Yes Low 4
3 user any svc-https dst-nat 8081 Low 4
show aaa authentication captive-portal "vbn-guest"
Captive Portal Authentication Profile "vbn-guest"
Parameter Value
Default Role vbn-guest
Default Guest Role guest
Server Group default
Redirect Pause 1 sec
User Login Enabled
Guest Login Disabled
Logout popup window Enabled
Use HTTP for authentication Disabled
Logon wait minimum wait 5 sec
Logon wait maximum wait 10 sec
logon wait CPU utilization threshold 60 %
Max Authentication failures 0
Show FQDN Disabled
Authentication Protocol PAP
Login page /auth/index.html
Welcome page /auth/welcome.html
Show Welcome Page Yes
Add switch IP address in the redirection URL Disabled
Adding user vlan in redirection URL Disabled
Add a controller interface in the redirection URL N/A
Allow only one active user session Disabled
White List N/A
Black List N/A
Show the acceptable use policy page Disabled
User idle timeout N/A
Redirect URL N/A
Bypass Apple Captive Network Assistant Disabled
URL Hash Key N/A
show rights vbn-guest-logon
Valid = 'Yes'
CleanedUp = 'No'
Derived Role = 'vbn-guest-logon'
Up BW:No Limit Down BW:No Limit
L2TP Pool = default-l2tp-pool
PPTP Pool = default-pptp-pool
Number of users referencing it = 0
Periodic reauthentication: Disabled
DPI Classification: Enabled
Youtube education: Disabled
Web Content Classification: Enabled
IP-Classification Enforcement: Enabled
ACL Number = 81/0
Openflow: Disabled
Max Sessions = 65535
Check CP Profile for Accounting = TRUE
Captive Portal profile = vbn-guest
Application Exception List
Name Type
Application BW-Contract List
Name Type BW Contract Id Direction
access-list List
Position Name Type Location
1 global-sacl session
2 apprf-vbn-guest-logon-sacl session
3 vbn-guest-control session
4 vbn-guest-captiveportal session
global-sacl
vbn-guest-control
Valid = 'Yes'
CleanedUp = 'No'
Derived Role = 'vbn-guest'
ACL Number = 84/0
Openflow: Disabled
Name Type
access-list List
2 apprf-vbn-guest-sacl session
3 vbn-guest session
global-sacl
vbn-guest
1 any any svc-dhcp permit Low 4
2 user my-dns svc-dns permit Low 4
3 user controller svc-https dst-nat 8081 Low 4
4 user any any route src-nat Low 4
#show ip access-list vbn-guest
vbn-guest
show aaa profile "vbn-guest"
AAA Profile "vbn-guest"
Parameter Value
Initial role vbn-guest-logon
MAC Authentication Profile N/A
MAC Authentication Default Role guest
MAC Authentication Server Group default
802.1X Authentication Profile N/A
802.1X Authentication Default Role guest
802.1X Authentication Server Group N/A
Download Role from CPPM Disabled
Set username from dhcp option 12 Disabled
L2 Authentication Fail Through Disabled
Multiple Server Accounting Disabled
Max IPv4 for wireless user 2
RADIUS Accounting Server Group N/A
RADIUS Roaming Accounting Disabled
RADIUS Interim Accounting Disabled
XML API server N/A
RFC 3576 server N/A
User derivation rules N/A
Wired to Wireless Roaming Enabled
SIP authentication role N/A
Device Type Classification Enabled
SSID is open
Enforce DHCP Disabled
PAN Firewall Integration Disabled
Open SSID radius accounting Disabled
#show wlan virtual-ap "email capture-vap_prof"
Virtual AP profile "email capture-vap_prof"
Parameter Value
AAA Profile email capture-aaa_prof
802.11K Profile default
Hotspot 2.0 Profile N/A
SSID Profile email capture-ssid_prof
Virtual AP enable Enabled
VLAN 32
Forward mode split-tunnel
Allowed band all
Band Steering Enabled
Cellular handoff assist Disabled
Openflow Enable Disabled
Steering Mode prefer-5ghz
Dynamic Multicast Optimization (DMO) Enabled
Dynamic Multicast Optimization (DMO) Threshold 6
Drop Broadcast and Unknown Multicast Disabled
Convert Broadcast ARP requests to unicast Enabled
Authentication Failure Blacklist Time 3600 sec
Deny inter user traffic Disabled
Deny time range N/A
DoS Prevention Disabled
HA Discovery on-association Enabled
Mobile IP Enabled
Preserve Client VLAN Disabled
Remote-AP Operation standard
Station Blacklisting Enabled
Strict Compliance Disabled
VLAN Mobility Disabled
WAN Operation mode always
FDB Update on Assoc Disabled
WMM Traffic Management Profile N/A
Anyspot profile N/A
