Frequent Contributor I
Sending H3C terminate session disconnect wired telephone
Hi
I have scenario where I have Avaya phones with laptops in daisy chain
All together they are authenticating via ClearPass: ip phone via MAC-auth, laptop via 802.1x.
because I'm deploying OnGuard i send terminate session after health web-based policy, defualt [H3C Terminate session]
After sending this telephones are disconnecting from switche port
After some investigation I have found in log for that session that ther'is error in ClearPass to find propoer attributes to send in [H3C Terminate Session]
In logs I have found:
WARN Util.ParameterizedString - getReplacedStrings: Failed to replace parameString =%{Radius:IETF:User-Name}, error=No values for param=Radius:IETF:User-Name
WARN Core.PETaskRadiusCoAEnfProfileBuilder - addParamsFromParameterizedProfile: Failed to find finalValue for name= Radius:IETF:User-Name value = %{Radius:IETF:User-Name}. Searching attributes from battery
WARN Util.ParameterizedString - getReplacedStrings: Failed to replace parameString =%{Radius:IETF:Calling-Station-Id}, error=No values for param=Radius:IETF:Calling-Station-Id
WARN Core.PETaskRadiusCoAEnfProfileBuilder - addParamsFromParameterizedProfile: Failed to find finalValue for name= Radius:IETF:Calling-Station-Id value = %{Radius:IETF:Calling-Station-Id}. Searching attributes from battery
I suspect that this session ternation doesn;t work as expected and terminate all sessions on port, so my phone dosconnect
The switch is Comware HPE 5130 HI
Someone have similar problem ?
regards
Karol
Re: Sending H3C terminate session disconnect wired telephone
That means there is no active RADIUS session for the device.
| Tim Cappalli | Aruba Security | @timcappalli | timcappalli.me |
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
Hi
So what You could recommend to work termination only for laptop ?
Karol
No, you need to see why there is no RADIUS session for the device you’re trying to disconnect.
Hi
I had made packet capture from ClearPass and Radius debug from the comware switch and I found that CPPM send valid use-rname and MAC-address (Calling-Station-Id) to terminate session to switch port.
But still don't know why IP telephone disconnect,
I enclose I packet capture dump
I have logged case in HPE support for the switch
regards
Karol
Regular Contributor I
Alternatively you could use the bounce client option in the agent enformcent to perform a bounce from the client.
- - - - Aruba ACCX #748, ACDX #758, ACMP, ACEAP | HPE Master ASE - - - -
- - - - - - - Feel free to give kudos or accept as a solution! - - - - - - - - -
Hi Fabian
I have already reconfigured it to agent bounce port, but I thought about it rather as temporary solution, but maybe It will be the only solution for me
regards
Karol
