Highlighted
Sonos and airgroups
Trying to get a Sonos speaker visible on our airgroup enable network. (ArubaOS 6.5.4.7) Apple TV/Chromecast works just fine. Found a set of airgroup sonos  requried services which I've added to the mobility controller.
Sonos speaker connects to a PSK network with device checked using DHCP signature in order to allow it on. We've got 2 vlans that airgroups work over
My phone is in 1 vlan , Sonos device in the other.
show airgroup server gives
78:28:ca:6e:0f:d4  10.241.89.68   mDNS,DLNA  sonos7828CA6E0FD4                     Sonos       3887  wireless        airgroup_devices         78-28-CA-6E-0F-D4       airgroup-ap-xb-1
show airgroup users | begin as1558
Gives
c8:3c:85:60:b8:8d  10.241.88.29    mDNS,DLNA                             3886  airgroup_devices                 as1558-1AD9  airgroup-ap-xb-1
However the sonos app on my phone can't find the speaker. I get a mesage saying "You're on the euroam wireless network but Sonos isn't. Goto settings ->WifI and change to the network Sonos is on.
Sonos Airgroup service
airgroupservice "Sonos"
id "urn:schemas-upnp-org:service:GroupRenderingControl:1"
id "urn:schemas-sonos-com:service:Queue:1"
id "urn:schemas-upnp-org:service:AVTransport:1"
id "urn:schemas-upnp-org:service:RenderingControl:1"
id "urn:schemas-tencent-com:service:QPlay:1"
id "urn:schemas-upnp-org:service:GroupManagement:1"
id "urn:schemas-upnp-org:service:ZoneGroupTopology:1"
id "urn:schemas-upnp-org:service:DeviceProperties:1"
id "urn:schemas-upnp-org:service:MusicServices:1"
id "urn:schemas-upnp-org:service:AlarmClock:1"
id "urn:schemas-upnp-org:device:ZonePlayer:1"
id "urn:schemas-upnp-org:service:SystemProperties:1"
id "urn:schemas-upnp-org:service:ContentDirectory:1"
id "urn:schemas-upnp-org:service:ConnectionManager:1"
id "urn:smartspeaker-audio:service:SpeakerGroup:1"
id "urn:schemas-upnp-org:device:MediaServer:1"
id "urn:schemas-upnp-org:service:AudioIn:1"
id "urn:schemas-upnp-org:device:EmbeddedNetDevice:1"
id "urn:schemas-upnp-org:service:EmbeddedNetDeviceControl:1"
id "urn:schemas-upnp-org:service:HTControl:1"
TCP ports enabled
80,445,3400,3500,443
UDP
136-139,1900,1901,6969
So is anyone running Sonos devices on an airgroup enabled setup ?
Rgds
Alex
Accepted Solutions
Highlighted
Re: Sonos and airgroups
O.k. after a bit of tweaking managed to remove the allow all ACL .. and it still works over multiple vlans
*think* acl list is
TCP
80,445,3400,3401,443,3500,1400
UDP
View solution in original post
All Replies
Highlighted
Alex
You will need to have th Sonos device and your phone on the same VLAN for you to be able to access it using their app.
Unfortunately from my experience the sonos app does not support routing between subnets / vlans to get between the phone and speaker.
Regards
Tom
Highlighted
Humph!
Guess that explains why it worked at home  with iphone on eduroam and speaker via wired port ... same vlan :-(
Given that we're planning on rolling out airgroups over multiple VLANS not sure I can ensuire that single user has all their devices on the same vlan :-(
Rgds
Alex
Highlighted
Hmmm
o.k. Sonos  on vlan 3887
DLNA Media
Spotify
Tweaked my iphone to also be on vlan 3887
(arubadev2) #show airgroup users | include as1558
c8:3c:85:60:b8:8d 10.241.89.234 mDNS,DLNA 3887 as1558-airgroup-devices as1558-1AD9 airgroup-ap-xb-1
only difference between  Roles airgroup_devices and as1558-airgroup-devices is placement of my iPhone into the same VLAN as the Sonos device.
Still can't see it
Highlighted
And it works, although I did change two things at the same time
1). Set ACL list to allow all for sonos and my iPhone
2). Changed Sonos from personal device to shared device
So with both devices on same vlan it works
Then reverted back to iphone on 1 VLAN Sonos on another and it still works.
Need to play with ACLs to see what was getting blocked, but definitely a step in the right direction
Highlighted
*think* acl list is
TCP
UDP
Highlighted
MVP
Hi Alex
Did you figure out if this part was needed?
Regards
John Solberg
-ACMX #316 :: ACCX #902 :: ACSA
Aruba Partner Ambassador
Intelecom/NetNordic - Norway
Remember to Kudo if a post helped you! || Problem Solved? Click "Accept as Solution" in a post!
Highlighted
Sadly the Sonos speaker I've got is a play:1 so doesn't support airgroups ... so in the end was immaterial whether it was set up as an airgroup server or client :-(
Highlighted
MVP
Ok, thanks for answering 😊 I ended up disabling Airgroup at this client since it wasn’t needed (someone had activated it at one time..), and it started working right away. Both Wired and Wireless clients was on the same vlan so..
Regards
John Solberg
Highlighted
I am having problems seeing any of my Sonos speakers on my network. I recently did the firm ware upgrade o 8.3.0.6, hoping it would help. But it did not.
Can anyone point me in a good direction to start to fiqure this out.
My info is below.
I have 3 type 215 AP's
Version 8.3.0.6
Build Time: 2019-02-14 09:07:11 UTC (build 69128) by p4build
