Occasional Contributor I
Timeout on guest portal with Instant
I am wondering if it's possible to have the following use case/scenario supported on Instant.
I want a captive portal where a user just has to click acknowledge. However, after a period of time (x hours), I want to user to get kicked off and have to click through the terms again.
Is this possible to do using only Instant without clearpass? I found some info that indicated that this might be possible setting the reauth interval. However, I tried setting this to 5 minutes, and even after 5 minutes my devices can still browse without haveingto go through the captive portal acknoledgement page again.
Thanks for the help!
Re: Timeout on guest portal with Instant
Try an reauth interval longer than the inactivity time (1000 seconds by default).
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
I gave that a shot and it doesn't seem to be working
For testing, I now have an inactivity timeout on the SSID of 5 minutes, I have the option to deauth inactive clients checked, and I have a reauth interval of 7 minutes. This is all with MAC auth on that SSID.
If I connect a client and wait >7 minutes, the client is still able to browse without getting the captive portal page again. It looks like if I totally disconnect and reconnect, I get the portal page, but I want this to take place mid-browsing if the reauth interval period is exceeded,
