Using ClearPass Radius for authentication on Always on VPN
Hi Guys,
I'm having difficulty settings up ClearPass to be used as the Radius Server for my evaluation of Always on VPN. The NPS is set to forward all requests to ClearPass and hopefully receive an allow or deny message back.
I have set up a service, policy, roles and role mappings (see attachments) however it's not able to classify the login as one thing or another.
Could anyone suggest how I go about this instead?
Re: Using ClearPass Radius for authentication on Always on VPN
You can’t use a certificate’s value in service categorization as it hasn’t been presented yet.
| Tim Cappalli | Aruba Security | @timcappalli | timcappalli.me |
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
From the radius request details
Radius:IETF:User-Name
From the computed attributes
Certificate:Subject-AltName-msUPN
Is there another way to make sure these have to match to work?
You can only use those in policy, not service categorization.
Thanks Tim that makes sense.
I'll try that and see what happens.
Okay so I've created this instead.
Still allows access even though it shouldn't as user-name and msUPN are different accounts (they are both valid accounts though).
If the msUPN is an invalid account it certainly doesn't work.
Did you ever get this fully working? We are about to start testing AOVPN and i'd rather use clearpass to than build an M$ server.
