We recently renewed our Wildcard cert and I went ahead and uploaded it to our Virtual Controller for use of the guest registration through the captive portal.
However, after the Guest logs in the redirect to https://captiveportal-login.DOMAIN.com throws an error:
NET::ERR_CERT_AUTHORITY_INVALID
When I open up the certificate that's presented, it shows only the certificate and nothing for the certificate path. I'm fairly certain this was an issue since this was built, and don't think it has anything really to do with the new cert (but just wanted it to be known).
I took the PFX that we received and converted it to a PEM using OPENSSL. The uploads to the ClearPass server of the certificate and key separately went in no problem and I can see the whole path. I uploaded the wildcard cert under the Captive Portal Server in the virtual controller along with the CA server and root under "CA."
Everything looks alright, but I'm not sure why it's not presenting the path.
