Highlighted
Occasional Contributor I
problem using ClearPass
First, if this is not the correct forum for my question, please point me in the right direction.  None of the options seemed quite right but this one seemed the closest.
I am Using ClearPass OnGuard 6.6.10, installed by my company's help desk on my personal Win10 laptop.  First thing in the morning I open the "hidden" icons in my system tray and right-click on ClearPass.  The menu opens but is blacked out.  I can drag my mouse over it and the entries re-appear, but the 'connect' does nothing.  If I open ClearPass from the desktop (full app interface) the window is all scrambled.  The only way I've found to regain control is to either reboot, or use the menu from the system tray icon to 'exit' - the only entry in that menu that works.  Once I exit, I can restart ClearPass from the desktop and everything is again working.  Until the next morning.
Accepted Solutions
Highlighted
Super Contributor II
Re: problem using ClearPass
TAC is Tech support. You will need to know your Clearpass account information / Serial numbers in order to opena. case. I'm guessing your and end user, and do not administer the Clearpass platform. If so, you would have to work with your Support staff to get a case open with Aruba TAC.
Dustin Burns
Senior Mobility and Access Engineer @WEI
ACMX #509 | ACCX #1272 | ACSA | ACDA | ACEA | CCNP | CCDP | CCNA Wireless
If my post address your queries, give kudos and accept as solution!
View solution in original post
All Replies
Highlighted
This sounds like an issue you might want to bring up to TAC. Either Agent installation problem, or something else to troubleshoot on the computer.
Dustin Burns
Highlighted
Dustin-Burns ,,
Who is TAC and how do I put my question there?
As you can tell, I'm "not from 'round here" and don't come this way often.
Highlighted
Dustin Burns
Highlighted
You are correct.  While I work in the IT dept.of my company, ClearPass is outside of my lane.  For that I'm just another end user.  I will contact my help desk.  Thank you.
