Contributor II
sms with code validation
My customer wants a captive portal in clearpass with a form requesting the cell number and sending an SMS with a code that the guest use to access to the wifi.
I know that i need a sms gateway, but do  i need something else?, can i do this with clearpass?.
do yo have some document with this?
MVP Expert
MVP Expert
Re: sms with code validation
The only thing you need is to configure the sms provider in ClearPass Guest.
See attachment
Kind Regards Marcel Koedijk
HPE ASE Flexnetwork | ACMP | ACCP | Ekahau ECSE Design - Was this post usefull, Kudos are welcome.
Contributor II
OK, thank, i know that i need configure the sms gateway, but how can i send a  code by sms to the guest and use it for the guest ingress to the wifi.
How do i need to configure the self-registration page for this?
do you have the steps?
Contributor I
Self Registration via SMS is like via E-Mail.
A quick search for an easy guide: https://www.youtube.com/watch?v=uGCM83HoEj4
