Hey,
for monitoring reasons I need to know if a switch is runnig an unsaved config.
Hardware is for instance a HPE Aruba 2530-24G-PoE+ (J9773A)
with Firmware YA.16.08.0001 (REST API V6.0)
On the CLI I can use the command:
2530-24G-PoE(config)# show config status
And get the response:
The running configuration matches the saved configuration.
or
The running configuration has been modified and not yet saved.
Is there a REST API equivalent to the CLI command?
Thanks.
