Wired Intelligent Edge
2930F Max VLANs
  • 1.  2930F Max VLANs
    Posted Apr 05, 2019 09:23 PM
    Is 256 really the hard limit of VLANs? I set the command max-vlans to 1024 and the running config confirms 1024, however when i try to vlan 1000-1499 it fails saying there is max of 256 VLANs.
    Is it a hard limit?
    I find it ironic on the lower 1950s I'm able to add more than 256 VLANs.
  • 2.  RE: 2930F Max VLANs
    MVP GURU
    Posted Apr 07, 2019 09:08 AM
    I think, yes it is a hard limit
    a campus switch don't really need more often of 1K vlans... (or it is a bad design !)
  • 3.  RE: 2930F Max VLANs
    Posted Apr 07, 2019 09:56 AM
    I don’t need the campus switch to route more than 256 VLANs, I have routers for that. I need the switch to support more than 256 VLANs at Layer2. The 2500 series and even the 1950s support that (as layer 2 switches)!
    The reason I got the 2930F was to do stacking which is not support in the 2500. In the 2930F data sheet:
    https://www.arubanetworks.com/assets/ds/DS_2930FSwitchSeries.pdf
    It says the following:
    Layer 2 switching
    • VLAN support and tagging support IEEE 802.1Q (4,094 VLAN IDs) and 2K VLANs simultaneously
    So how can I tag my ports with more than 256 VLANs when it says Layer2 can handle 2000 VLANs?
    Perry
  • 4.  RE: 2930F Max VLANs
    MVP GURU
    Posted Apr 07, 2019 12:10 PM
    with 2930F(-8G) and firmware 16.08
    it is possible to set max-vlans to 2048
    MAQ-2930F(config)# max-vlans
     <16-2048>             Enter an integer number.
    MAQ-2930F(config)# show vlan
     Status and Counters - VLAN Information
      Maximum VLANs to support : 2048
      Primary VLAN : DEFAULT_VLAN
      Management VLAN :
  • 5.  RE: 2930F Max VLANs
    Posted Apr 07, 2019 12:28 PM
    Yes I noticed that and I tried to set that to 1024. However when I try to add more than 256 VLANs I get an error message as I mentioned in my original post.
    Perry
  • 6.  RE: 2930F Max VLANs
    MVP GURU
    Posted Apr 07, 2019 12:30 PM
    Perry
    May be a bug... open a issue to the TAC
  • 7.  RE: 2930F Max VLANs
    MVP GURU
    Posted Apr 08, 2019 12:15 AM
    max-vlans requires switch to reboot...did you reboot it yet?
  • 8.  RE: 2930F Max VLANs
    Posted Apr 08, 2019 07:20 AM
    Yes I did, but I'm in a stack so perhaps one of the members didn't get a proper reboot? I'm pretty sure I did both memembers, but I will try again to be sure. I've also opened a case with HPE.
    Perry
  • 9.  RE: 2930F Max VLANs
    Posted Apr 08, 2019 03:05 PM
    So it seems that I needed to power cycle the switches. Previously I did a reload command from the CLI, which rebooted both switches in the stack.
    After power cycling the switches the max-vlan setting was applied.
    Thanks all!
  • 10.  RE: 2930F Max VLANs
    Posted Aug 31, 2022 05:26 PM
    I want to thank you for this thread.  I ran into the same issue.   Regardless what the switch is designated for.   I run port to port VLAN isolation usually on HP1950, HP1920s, power edge, ect.
    Example: First switch port 1/0/1 untagged vlan 1101, port 1/0/2 1102, with a trunk uplink.  Second switch port 1/0/1 untagged vlan 1201, ect.
    This allows me to isolate ports via the router.  Then i can see all my devices in one place via MAC/DHCP.
    Solution for me was both:  below and then a reboot.
      Management VLAN :
