Wired Intelligent Edge
2930F VSF stacking - configuration
This thread has been viewed 43 times
  • 1.  2930F VSF stacking - configuration
    Posted Sep 06, 2018 10:05 AM
    I've got two 2930F that have some configuration but no VSF.
    Right now, I'd like to setup the VSF. I'd like to understand if it will loose all the configuration if I setup the VSF.
  • 2.  RE: 2930F VSF stacking - configuration
    MVP GURU
    Posted Sep 06, 2018 05:33 PM
    You're going to lose Switch configuration (it will be defaulted after VSF will be joined) of the VSF Member that will join the VSF Domain as Standby VSF Member (since, as very first step, you will form a fragmented VSF Domain on the Switch that, supposedly, is going to act as VSF Commander)...if I recall it correctly.
  • 3.  RE: 2930F VSF stacking - configuration
    Posted Sep 06, 2018 08:07 PM
    Hi mathsanches,
    As parnassus said, you would lose any configuration of the switch that you would add to the VSF stack, however whatever you have on the commander, or the existing switch, will retain its configuration, only the port numbering will change with the added stack member ID (I.E. 1/23 instead of 23).  You can use the strict provisioning method to force one switch to become the commander and the other to become standby.  In that case, the commander would retain configuration and the standby would lose it's configuration, joining the commander as one logical switch in the stack.
    Please refer to the Management and Configuration Guide which shows how to setup a VSF stack, starting on page 728.
    https://support.hpe.com/hpsc/doc/public/display?docId=a00050273en_us
