Wired Intelligent Edge
2930M SNMP configuration
  • 1.  2930M SNMP configuration
    Posted May 28, 2019 12:59 PM
    What is the equivilant in Aruba switches for the configuration below from Cisco switch?
    snmp-server chassis-id xxxxx
    snmp-server enable traps snmp coldstart warmstart
    snmp-server enable traps envmon fan shutdown supply temperature status
    - I couldnt find any option to set "chassis-id". What is the default value used in Aruba switches
    - For SNMP traps, I can see the following in MCG guide
    "The default event scenarios for currently generated traps on ArubaOS-Switches are:
    • Device cold start notifications
    • Device warm start notifications
    • Port down notifications
    • Port up notifications
    • Authentication failure notifications
    • Enterprise change notifications
    • Intrusion alarm notifications"
    but what about fan?
    also, I am not able to see any of these traps in the command "show snmp-server traps"
    Thank you,
  • 2.  RE: 2930M SNMP configuration
    Posted May 28, 2019 03:38 PM
    Chassis-ID is not available at the Aruba switches.
    You can use the following:
    snmp-server location
    or
    snmp-server contact
    I'm not sure which traps are send and which one not. Maybe setup a test with this. Other options are SNMP get or syslog
