Wired Intelligent Edge
last person joined: 2 hours ago
3810m stack connecting to 2930F stack
  • 1.  3810m stack connecting to 2930F stack
    Posted Sep 26, 2019 11:58 AM
    I have a stack of 2 3810m switches using the backplane stacking module (JL084a) which will use the 10 gb sft front card (JL083a) to connect to the 2930F stack.
    The 2930F is currently a 4 swtich stack.  How do I go about configuring stacking between all of these?
    Do I just add the 3810's as a member in the existing 2930f stack? will having the 2 stacks mess up things? Do I set it as member 5 with a lower priority? I have never done this with the different models and different stacks. thanks!
  • 2.  RE: 3810m stack connecting to 2930F stack
    MVP GURU
    Posted Sep 26, 2019 01:32 PM
    You can't mix Aruba 3810M (Hardware) Stack's member into an Aruba 2930F (VSF based) Stack and viceversa.
    Using other words each Stack admits joining of Switches of the same family of its members.
    Stack's members should belong to the same Switch series (either Aruba 3810M or Aruba 2930F or Aruba 2930M or Aruba 5400R zl2) and each Switch series is able to form Stack with its very same members (and that is true no matter the stacking technique is the same, backplane versus frontplane...so an Aruba 5406R zl2 VSF can't stack with an Aruba 2930F VSF and viceversa...the same is true between Aruba 3810M and Aruba 2920 or Aruba 2930M).
    At best, once Stacks are formed, you can interconnect them as they were two single switches (which is true because a Stack shows itself to its peering devices as a single logical entity).
  • 3.  RE: 3810m stack connecting to 2930F stack
    Posted Sep 26, 2019 03:18 PM
    Thanks. I misunderstood the scope of this project.  The DAC cable will be doing layer 2 not stacking and the model stacking difference makes absoulute sense.  thanks!
