Well...that 91.5% of (busy) CPU dedicated to HTTP service is quite interesting (if the Web Management is truly disabled who else is using HTTP?).
Have you tried also the no web-management ssl command too?
What show cpu slot all command reports?
Is the VSF actually OK? does the show vsf command report anything strange?
Do you have process-tracking enabled (to be enabled before the show cpu command with process-tracking command; to disable use the no process-tracking command after exiting with Ctrl-C)? I don't believe.
Please paste the output of show flash and show uptime commands too (remove any Serial Number or MAC address before posting).
We have SNMP and Web Management both enabled but our VSF (older KB.16.05.0007 version) runs with these values:
VSF# show cpu
5 percent busy, from 300 sec ago
1 sec ave: 2 percent busy
5 sec ave: 4 percent busy
1 min ave: 3 percent busy
