This may be a weird question - I have a 5400 that I am currently in the process of setting up for future use.
At this point it is connected only via its' OOBM port, I am not on location and I need to change the OOBM interface network.
If I had direct access I would either use console or add a different IP on one of the vlans connected with an uplink to allow me to change the OOBM address, but currently I lack that ability.
Running
# oobm ip address [addr]/[mask]
returns:
Cannot configure more than one IPv4 address on OOBM interface.
Instead of changing the address, for obvious reasons I can't run "no oobm ip address" at this stage.
So that leaves me with the question how can I fix this?
Can I edit the boot-config and reboot the switch?
