Wired Intelligent Edge
[5406] DHCP Server
  • 1.  [5406] DHCP Server
    Posted Dec 17, 2018 10:40 AM
    Hi All,
    We need to move the DHCP server function from a Cisco switch to an Aruba Switch (5406). We configure the VLAN interfaces including IP and enable dhcp-server.
    We created the address pools correctly, but after activating DHCP Server globally and disabling the cisco switch the stations were unable to receive the IP address.
    The output of  show dhcp-server binding command was:
    Status and Counters - DHCP Server
     Address Pools         : 18
      Automatic Bindings    : 10
      Manual Bindings       : 0
      Expired/Free Bindings : 7915
      Malformed Messages    : 382
      Messages Received
      BOOTREQUEST           : 2824
      DHCPDISCOVER          : 1275
      DHCPREQUEST           : 729
      DHCPDECLINE           : 1
      DHCPRELEASE           : 10
      DHCPINFORM            : 809
      Messages Sent
      BOOTREPLY             : 423
      DHCPOFFER             : 57
      DHCPACK               : 365
      DHCPNAK               : 1
    The DHCP configuration is similar to this one:
    ip route 0.0.0.0 0.0.0.0 10.16.10.254
    Ip routing
    vlan 10
     name "Test_VLAN"
     untagged A1,A3
     tagged A8
     ip address 192.168.1.1 255.255.255.0
     dhcp-server
     exit
    dhcp-server pool "Test-pool"
       default-router "192.168.1.1"
       dns-server "192.168.1.2"
       domain-name "mydomain.com"
       netbios-name-server "192.168.1.2"
       lease 00:00:05
       network 192.168.1.0 255.255.255.0
       range 192.168.1.10 192.168.1.200
       option 4 ip "192.168.1.2"
       option 9 ip "192.168.1.3"
       exit
    dhcp-server enable
    Do you have any tip?
    Thank you
  • 2.  RE: [5406] DHCP Server
    MVP GURU
    Posted Dec 17, 2018 04:41 PM
    Try to set the dhcp-server to be authoritative for the pool "Test-pool" (using the command authoritative within the dhcp-server pool "Test-pool" context)...and is 5 minutes lease time correct (lease 00:00:05)?
  • 3.  RE: [5406] DHCP Server
    Posted Dec 19, 2018 08:41 AM
    Hi Parnassus.
    We will try it on next maintenance window.
    The current DHCP lease configuration is 8 hours. 00:08:00
    Thank you
  • 4.  RE: [5406] DHCP Server
    MVP GURU
    Posted Dec 19, 2018 09:08 AM
    OK, 8 hours is far more reasonable as DHCP lease time.
  • 5.  RE: [5406] DHCP Server
    Posted Dec 26, 2018 07:13 AM
    Hi Parnassus.
    Thank you very much. Worked perfectly.
    best regards,
    Ed
