Wired Intelligent Edge
AOS-CX - IP directed-broadcast and ACL
This thread has been viewed 35 times
  • 1.  AOS-CX - IP directed-broadcast and ACL
    Posted Oct 25, 2019 04:04 AM
    I have an AOS-CX 8320 VSX cluster which acts as the default gateway for multiple VLANs, like 1 server VLAN and 2 client VLANs. The customer wants to use Wake-on-LAN (WoL).
    I enabled IP directed-broadcast on the client SVI's and this works. Now I would like to limit the number of servers that would be able to send WoL packets.
    I don't see an option to add an ACL directly to the IP directed-broadcast command, so I guess the only option would be to configure an ACL on SVI level. As far as I can see there is only an option to apply a policy in the routed-in direction. The WoL packet from the server to client is outbound for the client SVI, so I have to add the ACL to the server SVI.
    Is that correct?
    This is a "live" environment so I cannot easily test, but below is the config snippet I would like to use.
    class ip class-ipdb
        1 ignore udp 172.18.19.13 any eq 7
        2 match udp any any eq 7
    policy policy-ipdb
        10 class ip class-ipdb action drop
    interface vlan19
        vsx-sync active-gateways
        description servers
        ip address 172.18.19.253/24
        active-gateway ip 172.18.19.254 mac 00:00:00:00:00:19
        apply policy policy-ipdb routed-in
    interface vlan21
        description clients1c
        ip address 172.18.21.253/24
        active-gateway ip 172.18.21.254 mac 00:00:00:00:00:21
        ip helper-address 172.18.19.1
        ip helper-address 172.18.19.2
        ip helper-address 172.18.19.94
        ip directed-broadcast
    interface vlan22
        description clients2c
        ip address 172.18.22.253/24
        active-gateway ip 172.18.22.254 mac 00:00:00:00:00:22
  • 2.  RE: AOS-CX - IP directed-broadcast and ACL
    Posted Oct 25, 2019 08:26 AM
    This seems to be a very good option, with less configuration.
    An other alternative, focused on destintation, is to use Ingress VLAN ACL on the destination VLANs, but this is more work as you may have to insert ACL for all VLANs.
  • 3.  RE: AOS-CX - IP directed-broadcast and ACL
    Posted Dec 19, 2019 11:13 AM
    Did that end up working out as expected? I'm finishing the config on a vsx pair of 8320s that I need to WOL with.
    The is is the config on the 5412zl2 that is being replaced.
    ip udp-bcast-forward
    ip access-list extended wol-acl
    permit udp 172.24.0.40 0.0.0.0 172.25.255.255 0.0.0.0 eq 9
    exit
    ip directed-broadcast access-group wol-acl
  • 4.  RE: AOS-CX - IP directed-broadcast and ACL
    Posted Dec 20, 2019 03:33 AM
    The configuration worked for me
