Wired Intelligent Edge
AOS-S 3810 (KB.16.10.0002) show dhcp-relay DROPPED server responses ?
  • 1.  AOS-S 3810 (KB.16.10.0002) show dhcp-relay DROPPED server responses ?
    Posted Nov 25, 2019 11:13 AM
    Re:  AOS-S 3810 (KB.16.10.0002) show dhcp-relay DROPPED server responses ?
    Yes, we are using vlan "ip helper-address xx.xx.xxx.xxx"
    How can I see on the AOS-switch the dhcp-relay packets that are being dropped or at least see why they are being dropped  (approximately 2 dropped every 15 mintes) ??
    DHCP Relay Statistics:
    Client Requests   Server Responses
    Valid     Dropped  Valid      Dropped
    359919      0        39257     7278
    # Thanks # Gracias # Merci # ありがとう # Danke # Spasiba # 감사합니다 # Toda # Cheers # Dhanyawaad # Ahsante # Xièxiè # shukran #
  • 2.  RE: AOS-S 3810 (KB.16.10.0002) show dhcp-relay DROPPED server responses ?
    MVP GURU
    Posted Nov 27, 2019 04:19 AM
    Hi aoscx-noob, do you have check the log ? (and enable more debug ?)
  • 3.  RE: AOS-S 3810 (KB.16.10.0002) show dhcp-relay DROPPED server responses ?
    Posted Dec 04, 2019 10:35 AM
    >>  # DEBUG ALL   <<<<  crashed my 8320 AOSCX unit:
    HPE-AOSCX8320-# deb all
    Dec 4 09:28:01 crash-handler[318]: ops-switchd crashed, crash processing in progress
    Dec 4 09:28:01 crash-handler[318]: RebootLibPh1: Reboot triggered due to ops-switchd crashed
  • 4.  RE: AOS-S 3810 (KB.16.10.0002) show dhcp-relay DROPPED server responses ?
    MVP GURU
    Posted Dec 04, 2019 11:00 AM
    No a good idea to enable debug all on switch...
