It should work the same as on the other switches that do work. If it doesn't, either my information is incorrect, or this is a software defect.EDIT: I did not look right. The document I used,
the Switch Software Feature Matrix, appears to be public, so you can have a look yourself.
Check for the feature RBAC: Role Based Access Control, and see there confirmed that this feature is unavailable on the 2530. Sorry for the confusion, I think I checked local user role before, which is supported.
Original Message:
Sent: Feb 20, 2021 05:19 AM
Subject: AOS Switch - Create local user with Level-15 access
Hi Herman Robers
I am not able to create local user on the Aruba Switch Model 2530, the rest models which you have mentioned above the same commands are working fine to create a local user.
We are using version YA.16.10.0012 and the error is "Authorization group Level-15 does not exist" can you please help how it works for model 2350.
sandeep singh
Original Message:
Sent: Feb 09, 2021 07:04 AM
As far as I can see that feature was introduced on 16.02 only on the active platforms at that time (5400R/v2+v3, 2930F, 2920, 2620, 2530). So it is expected that the command is not available on your 5412 non R 'K' platform.
Original Message:
Sent: Feb 05, 2021 01:58 PM
Apologies for posting to an old topic but I am having the same issue.
On a
HP J8698A Switch 5412zl
Software revision K.16.02.0026
I ran "aaa authentication local-user <username> group Level-15 password plaintext" from the (config) prompt and got back "Authorization group Level-15 does not exist."
but on
HP J9851A Switch 5412Rzl2
Software revision KB.16.10.0007
The command runs properly and creates my user and prompts for the password.
Shane McCook
Original Message:
Sent: Jul 08, 2019 02:42 PM
Greetings!
The first example you used should be correct - the default group for manager-level permissions is "Level-15".
What switch model are you using, and what software version is it running? Did you get a specific error message when you tried the command?
