Wired Intelligent Edge
last person joined: 7 hours ago
Aruba 2530-48G switch unable to access to web interface
This thread has been viewed 50 times
  • 1.  Aruba 2530-48G switch unable to access to web interface
    Posted Aug 27, 2018 04:50 AM
    Hi all,
    I am using three 2530-48G switches named SW2, SW2 and SW3. In that, port 45+46 of SW1 trunks to 45+46 of SW2, and port 47+48 of SW1 trunks to 47+48 of SW3. Everything is ok untill i add a new VLAN in SW1 (not assign port to VLAN yet).
    The network operates normally, but something wrong with SW1:
            - Can ping to SW1 but cannot  access by web and ssh interfaces, only access through console menu.
            - Cannot remove new added VLAN in console menu
    Actually i always operate them just by web-interface. So it so difficult for me with others. Please help me to get over this problem?
    Thanks.
  • 2.  RE: Aruba 2530-48G switch unable to access to web interface
    Posted Aug 27, 2018 06:09 AM
    please post config at least of SW1.
    Since WebInterface is not working:
    • Go to console
    • Change from menu to CLI
    • issue "show config"
    Provide results here.
    Regards, Jörg
  • 3.  RE: Aruba 2530-48G switch unable to access to web interface
    MVP GURU
    Posted Aug 27, 2018 09:10 AM
    Hi
    @nvn199 wrote: Everything is ok untill i add a new VLAN in SW1 (not assign port to VLAN yet).
    Which VLAN Id you added?
    Generally adding a VLAN (without eventually assigning to that VLAN an IP Interface and untagging/tagging port(s) you need on the relevant switch) has not such damaging impact (not connecting anymore to Web Management)...at least if you simply created it as you wrote.
    The output of show running config would be of help to better diagnose what's going on.
  • 4.  RE: Aruba 2530-48G switch unable to access to web interface
    Posted Aug 27, 2018 11:26 PM
    This is the config:
    Startup configuration: 32
    ; J9772A Configuration Editor; Created on release #YA.15.17.0009
    ; Ver #07:c3.84.9c.63.ff.37.27:50
    hostname "SWITCH1"
    trunk 45-46 trk1 lacp
    trunk 47-48 trk2 lacp
    ip default-gateway 192.168.0.50
    interface 1
       no power-over-ethernet
       exit
    interface 2
       exit
    interface 3
       exit
    interface 4
       exit
    interface 5
    exit
    interface 6
       exit
    interface 7
       exit
    interface 8
       exit
    interface 9
       exit
    interface 10
       exit
    interface 11
       exit
    interface 12
       exit
    interface 13
       exit
    interface 14
       exit
    interface 15
       exit
    interface 16
       exit
    interface 17
       exit
    interface 18
       exit
    interface 19
       exit
    interface 20
       exit
    interface 21
       exit
    interface 22
       exit
    interface 23
       exit
    interface 24
       exit
    interface 25
       exit
    interface 26
       exit
    interface 27
       exit
    interface 28
    exit
    interface 29
       exit
    interface 30
       exit
    interface 31
       exit
    interface 32
       exit
    interface 33
       exit
    interface 34
       exit
    interface 35
       exit
    interface 36
       exit
    interface 37
       exit
    interface 38
       exit
    interface 39
       exit
    interface 40
       exit
    interface 41
       exit
    interface 42
       exit
    interface 43
       exit
    interface 44
       exit
    interface 45
       name "Trunk to SW2"
       exit
    interface 46
       name "Trunk to SW2"
       exit
    interface 47
       name "Trunk to SW3"
       exit
    interface 48
       name "Trunk to SW3"
       exit
    snmp-server community "public" unrestricted
    vlan 1
       name "DEFAULT_VLAN"
       untagged 1-44,49-52,Trk1-Trk2
    ip address 192.168.0.254 255.255.255.0
       exit
    vlan 140
       name "Wifi"
       no ip address
       exit
    management-vlan 140
    spanning-tree Trk1 priority 4
    spanning-tree Trk2 priority 4
    no tftp server
    no dhcp config-file-update
    no dhcp image-file-update
    password manager
  • 5.  RE: Aruba 2530-48G switch unable to access to web interface
    Posted Aug 28, 2018 06:41 AM
    you configured the new VLAN as "management VLAN". The switch will accept management connections only in that management vlan.
    Since management vlan has some other difficulties, I'd suggest, you do not use this function for now.
    So remove that configuration and you should be able to connect again.
    "no management-vlan" should be enough.
    Jörg
  • 6.  RE: Aruba 2530-48G switch unable to access to web interface
    MVP GURU
    Posted Aug 28, 2018 08:55 AM
    As Jörg wrote, the problematic configuration line is:
    management-vlan 140
    You have not configured any port to be untagged member of that VLAN (and you didn't assigned any IP to that VLAN 140)...so, basically, you locked out.
    Remove the above line from configuration file and reload it via Console port and you should be able to connect again to your Aruba 2530 using the configured IP 192.168.0.254 through any of its ports (1-44 <- untagged members of VLAN 1).
  • 7.  RE: Aruba 2530-48G switch unable to access to web interface
    Posted Aug 28, 2018 02:05 PM
    Greetings!
    Going into a bit more detail on the management VLAN — one thing to keep in mind if you do plan to use this feature is that the management VLAN does not participate in switch IP routing, so if your management workstations are on a different subnet from the management IP address, the switch will be unreachable.  If your goal is to limit management access to the switch, you may want to consider using the ip authorized-managers command or ACLs as an alternative.
  • 8.  RE: Aruba 2530-48G switch unable to access to web interface
    Posted Aug 28, 2018 11:31 PM
    It is done. I just "no management-vlan" .
    Thanks for all you help.
  • 9.  RE: Aruba 2530-48G switch unable to access to web interface
    MVP GURU
    Posted Aug 29, 2018 08:45 PM
    Just for reference: Management VLAN.
