Upcoming community maintenance Oct. 27th through Oct. 29th
For more info click here
Highlighted
Aruba 2530 8G POE+ switch manager password issues
Im new to Hp cli. I have 11 new of these switches to configure vlans and trunking for a project but i am having issue with the console login.
I entered the command below
HP-2530-8G-POEP(config)# password manager user-name "admin" plaintext "password"
But i get the prompt that password cannot be changed on a stack member switch.
On another switch, i entered the above command and it accept it but after restarting the device it does not accept the password i used and comes up as invalid password.  Can someone help me out as my project time is sticking fast!
Edmund
Highlighted
MVP Guru
Re: Aruba 2530 8G POE+ switch manager password issues
I wrongly clicked "Mee too" (I really hadn't your issue)...a part from that...do you remember to save your running configuration into startup configuration by issuing the write memory command?
With regards to the problem on stack member switch...have you defined a stack management configuration for your Switches or are they manageable singularly (each one with its own IP Address)?
Highlighted
Hi
Highlighted
After a couple of reset attempts are able to get the switch back to factory default and managed to set the password. Thanks for the help.
