Do you know the cable is working? Also, some switches have a mgmt port and console port close to each other, both RJ45. You will need to plug in the console port for serial connection, the mgmt port is an ethernet port.
Original Message:
Sent: Oct 25, 2021 04:30 PM
Subject: Aruba 2530 connecting from Putty serial
I have the same issue - enter 3 times does not do anything. Black screen with a blinking cursor is all I get in putty.
Zachary Parry
Original Message:
Sent: Jun 12, 2019 01:06 PM
Have you tried <enter> <enter> <enter> (three times the enter key)?
The ArubaOS console will wake up only after that sequence.
