Wired Intelligent Edge
last person joined: 4 hours ago
Aruba 2920 port Blocked by STP - Errors
This thread has been viewed 33 times
  • 1.  Aruba 2920 port Blocked by STP - Errors
    Posted Apr 02, 2019 03:50 PM
    I'm seeing these errors all day at a few of my remote location switches.
    **From log on switch**
    00076 ports: port 14 is now on-line
    00435 ports: port 14 is Blocked by STP
    00077 ports: port 14 is now off-line
    **From IMC**
    iMC alarm system found event (The interface 14 is UP.) and event (The interface 14 is DOWN.) had 3 intermittent failures
    All the ports doing so have a Cisco aironet 3600 series AP connected to them. Has anyone see then before and know what is going on? I was guessing maybe an LLDP or power negotation failure. Power draw is around 80w of the 370w available.
    Thanks in advance.
  • 2.  RE: Aruba 2920 port Blocked by STP - Errors
    MVP GURU
    Posted Apr 03, 2019 01:57 AM
    By default when port is UP (and there is not admin-edge port), it is blocked by STP for 3 sec (with RSTP)
    I think, you need to look access point log..
  • 3.  RE: Aruba 2920 port Blocked by STP - Errors
    Posted Apr 10, 2019 09:21 AM
    Thanks, I have opened a case with Cisco TAC.
  • 4.  RE: Aruba 2920 port Blocked by STP - Errors
    Posted Apr 10, 2019 12:56 PM
    Greetings!
    As noted by alagoutte, the STP port blocking is a default behavior when a port first comes up, and normally clears automatically. If you're seeing this occurring continually, the port is bouncing, and that could be either a power delivery issue or a problem with the connected AP itself causing it to continually reboot.
    Are you seeing anything in the switch event logs indicating a PoE delivery error on the switch port itself?
