This article discussed how to enable IPV4 BGP route debugging.
In the following example, switches Rack2sw1 and Rack2sw2 are configured for BGP routing.
Debugging for IPV4 BGP routing is enabled on switch Rack2sw1. The loopback zero interface on switch Rack2sw2 is deleted and then added. This cause a BGP route CHANGE and ADD message to be sent to the BGP neighbor.
Rack2sw1# debug destination session Rack2sw1# debug ip bgp route Rack2sw1# show debug
Debug Logging
Source IP Selection: Outgoing Interface Origin identifier: Outgoing Interface IP Destination: Session
Enabled debug types: ip bgp route
Rack2sw2(config)# no interface loopback 0 Rack2sw2(config)# interface loopback 0 ip address 2.2.2.2
0000:01:29:57.16 BGP eRouteCtrl:CHANGE 2.2.2.2 255.255.255.255 gw 192.168.12.2 BGP pref 200/0 metric 0/100 vl1 <Int Ext Delete Gateway Unicast Resolve> as 12 0000:01:29:57.36 BGP eRouteCtrl:rt_close: 1 route proto BGP_12.192.168.12.2+179 from 192.168.12.2
0000:01:30:02.06 BGP eRouteCtrl:ADD 2.2.2.2 255.255.255.255 gw 192.168.12.2 BGP pref 200/0 metric 0/100 vl1 <Int Ext Gateway ActiveU Unicast Resolve> as 12 0000:01:30:02.26 BGP eRouteCtrl:rt_close: 1 route proto BGP_12.192.168.12.2+179 from 192.168.12.2
