Problem:
Aruba 5412R zl2 Switch - Login issue
Unable to access the Switch via telnet or SSH.
Checked and found IP Authorize manager was configure for few IPs and hence CU was unable to access the switch with other IP address.
Asked CU to add the IP on Authorization list or to remove IP authorization. Provided the Configuration guide and steps for IP authorization. CU configured the the Switch and the issue is fixed.
