Wired Intelligent Edge
last person joined: 5 hours ago
Aruba S2500-24P stack problem
  • 1.  Aruba S2500-24P stack problem
    Posted Jan 17, 2019 04:28 AM
    I just bought a switch S2500-24P.
    I plugged it yesterday (at the reception), the stack led remains on after booting the OS.
    My S2500-48P, the light stays off.
    When I plug in an RJ45, no indicator lights up.
    Does anyone have an idea, a solution?
    Thank you
    Emmanuel
  • 2.  RE: Aruba S2500-24P stack problem
    Posted Jan 17, 2019 11:19 AM
    When you say stacking, did you use a dedicated stacking cable (DAC) and connected it to stacking interfaces on the two switches? Or did you just connect two random ports with a normal network cable? Can you connect to the switches with a console cable and check the logs and running config?
  • 3.  RE: Aruba S2500-24P stack problem
    Posted Jan 17, 2019 11:38 AM
    i'm not use stacking
    the s2500-48 is for my lab and the s2500-24 is for my office
    they are connect with two fibres lc-lc + gbic.
    When i received, i plugged the ac cable, the switch start and load.
    just one RJ45 port is plugged on other switch the time to configure it.
    and when load finish the stack led light up but not the rj45 light
  • 4.  RE: Aruba S2500-24P stack problem
    Posted Jan 21, 2019 07:12 AM
    Can you logon to the switches using a console cable?
  • 5.  RE: Aruba S2500-24P stack problem
    Posted Jan 21, 2019 01:15 PM
    with console cable yes i could
  • 6.  RE: Aruba S2500-24P stack problem
    Posted Jan 22, 2019 07:53 AM
    Try to do a factory reset of the new switch. Use the command 'restore factory_default stacking'
    Afterwards logon to the switch and check the logs for errors and warnings.
  • 7.  RE: Aruba S2500-24P stack problem
    Posted Jan 22, 2019 09:31 AM
    ok, i'll try this
    how can i see the log ?
  • 8.  RE: Aruba S2500-24P stack problem
    Posted Jan 22, 2019 04:49 PM
    ok, google is my friend :D
    (ArubaS2500-24P) #show log errorlog all
    Jan 22 23:05:29 <nanny 303079>  <ERRS> |nanny|  Restarted process /mswitch/bin/dpa, new pid 15867
    Jan 22 23:05:31 <dpa 399816>  <ERRS> |dpa|  mrvl_init_new_dev: /dev/ppe0 not found. Marvel Device initialization failed
    Jan 22 23:05:39 <nanny 303073>  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 15867] died: got signal SIGABRT
    Jan 22 23:05:39 <nanny 303080>  <ERRS> |nanny|  Please tar and email the file crash.tar to support@arubanetworks.com
    Jan 22 23:05:39 <nanny 303081>  <ERRS> |nanny| To tar type the following commands at the Command Line Interface: (1) tar crash (2) copy flash: crash.tar tftp: [serverip] [destn filename]
    Jan 22 23:05:43 <nanny 303029>  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 15867]: crash data saved in dir /flash//crash/process/1-22-2019@23-05-39/dpa@15867
    Jan 22 23:05:43 <nanny 303025>  <ERRS> |nanny|  Found core file /tmp/core.15867.dpa.S2500_65516, 24412160 bytes, compressing...
    Jan 22 23:06:00 <nanny 303079>  <ERRS> |nanny|  Restarted process /mswitch/bin/dpa, new pid 16058
    Jan 22 23:06:01 <dpa 399816>  <ERRS> |dpa|  mrvl_init_new_dev: /dev/ppe0 not found. Marvel Device initialization failed
    Jan 22 23:06:10 <nanny 303073>  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 16058] died: got signal SIGABRT
    Jan 22 23:06:10 <nanny 303080>  <ERRS> |nanny|  Please tar and email the file crash.tar to support@arubanetworks.com
    Jan 22 23:06:10 <nanny 303081>  <ERRS> |nanny| To tar type the following commands at the Command Line Interface: (1) tar crash (2) copy flash: crash.tar tftp: [serverip] [destn filename]
    Jan 22 23:06:13 <nanny 303029>  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 16058]: crash data saved in dir /flash//crash/process/1-22-2019@23-06-10/dpa@16058
    Jan 22 23:06:13 <nanny 303025>  <ERRS> |nanny|  Found core file /tmp/core.16058.dpa.S2500_65516, 24412160 bytes, compressing...
    Jan 22 23:06:30 <nanny 303079>  <ERRS> |nanny|  Restarted process /mswitch/bin/dpa, new pid 16249
    Jan 22 23:06:31 <dpa 399816>  <ERRS> |dpa|  mrvl_init_new_dev: /dev/ppe0 not found. Marvel Device initialization failed
    Jan 22 23:06:40 <nanny 303073>  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 16249] died: got signal SIGABRT
    Jan 22 23:06:40 <nanny 303080>  <ERRS> |nanny|  Please tar and email the file crash.tar to support@arubanetworks.com
    Jan 22 23:06:40 <nanny 303081>  <ERRS> |nanny| To tar type the following commands at the Command Line Interface: (1) tar crash (2) copy flash: crash.tar tftp: [serverip] [destn filename]
    Jan 22 23:06:43 <nanny 303029>  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 16249]: crash data saved in dir /flash//crash/process/1-22-2019@23-06-40/dpa@16249
    Jan 22 23:06:43 <nanny 303025>  <ERRS> |nanny|  Found core file /tmp/core.16249.dpa.S2500_65516, 24412160 bytes, compressing...
    (ArubaS2500-24P) #show log network all
    Jan 22 13:35:57 :212005:  <WARN> |ChassisManager|  Physical interface GE0/0/0 (interface index 0) administrative up
    Jan 22 13:35:57 :212005:  <WARN> |ChassisManager|  Physical interface GE0/0/1 (interface index 0) administrative up
    Jan 22 13:35:57 :212005:  <WARN> |ChassisManager|  Physical interface GE0/0/2 (interface index 0) administrative up
    Jan 22 13:35:57 :212005:  <WARN> |ChassisManager|  Physical interface GE0/0/3 (interface index 0) administrative up
    Jan 22 13:35:57 :212005:  <WARN> |ChassisManager|  Physical interface GE0/0/4 (interface index 0) administrative up
    Jan 22 13:35:57 :212005:  <WARN> |ChassisManager|  Physical interface GE0/0/5 (interface index 0) administrative up
    Jan 22 13:35:57 :212005:  <WARN> |ChassisManager|  Physical interface GE0/0/6 (interface index 0) administrative up
    Jan 22 13:35:57 :212005:  <WARN> |ChassisManager|  Physical interface GE0/0/7 (interface index 0) administrative up
    Jan 22 13:35:57 :212005:  <WARN> |ChassisManager|  Physical interface GE0/0/8 (interface index 0) administrative up
    Jan 22 13:35:57 :212005:  <WARN> |ChassisManager|  Physical interface GE0/0/9 (interface index 0) administrative up
    Jan 22 13:35:57 :212005:  <WARN> |ChassisManager|  Physical interface GE0/0/10 (interface index 0) administrative up
    Jan 22 13:35:57 :212005:  <WARN> |ChassisManager|  Physical interface GE0/0/11 (interface index 0) administrative up
    Jan 22 13:35:57 :212005:  <WARN> |ChassisManager|  Physical interface GE0/0/12 (interface index 0) administrative up
    Jan 22 13:35:57 :212005:  <WARN> |ChassisManager|  Physical interface GE0/0/13 (interface index 0) administrative up
    Jan 22 13:35:57 :212005:  <WARN> |ChassisManager|  Physical interface GE0/0/14 (interface index 0) administrative up
    Jan 22 13:35:57 :212005:  <WARN> |ChassisManager|  Physical interface GE0/0/15 (interface index 0) administrative up
    Jan 22 13:35:57 :212005:  <WARN> |ChassisManager|  Physical interface GE0/0/16 (interface index 0) administrative up
    Jan 22 13:35:57 :212005:  <WARN> |ChassisManager|  Physical interface GE0/0/17 (interface index 0) administrative up
    Jan 22 13:35:57 :212005:  <WARN> |ChassisManager|  Physical interface GE0/0/18 (interface index 0) administrative up
    Jan 22 13:35:57 :212005:  <WARN> |ChassisManager|  Physical interface GE0/0/19 (interface index 0) administrative up
    Jan 22 13:35:57 :212005:  <WARN> |ChassisManager|  Physical interface GE0/0/20 (interface index 0) administrative up
    Jan 22 13:35:57 :212005:  <WARN> |ChassisManager|  Physical interface GE0/0/21 (interface index 0) administrative up
    Jan 22 13:35:57 :212005:  <WARN> |ChassisManager|  Physical interface GE0/0/22 (interface index 0) administrative up
    Jan 22 13:35:57 :212005:  <WARN> |ChassisManager|  Physical interface GE0/0/23 (interface index 0) administrative up
    Jan 22 13:35:57 :212005:  <WARN> |ChassisManager|  Physical interface GE0/1/1 (interface index 0) administrative up
    Jan 22 13:35:57 :212005:  <WARN> |ChassisManager|  Physical interface GE0/1/0 (interface index 0) administrative up
  • 9.  RE: Aruba S2500-24P stack problem
    Posted Jan 22, 2019 04:59 PM
    (ArubaS2500-24P) #show log system all
    Jan 22 22:34:50  KERNEL: klogd started: BusyBox v1.01 (2018.06.26-11:25+0000)
    Jan 22 22:34:50  KERNEL: 0:<5>0:
    Jan 22 22:34:50  KERNEL: Aruba Networks
    Jan 22 22:34:50  KERNEL: ArubaOS Version 7.4.1.10 (build 65516 / label #65516)
    Jan 22 22:34:50  KERNEL: Built by p4build@lesbos on 2018-06-26 at 04:31:13 PDT (gcc version 3.4.3)
    Jan 22 22:34:50  KERNEL: 0:Using default Mac address
    Jan 22 22:34:50  KERNEL: 0:XLR Physical Address Exclude Region: 0x3c00000
    Jan 22 22:34:50  KERNEL: 0:HACK: forcing xlr_board_major_version to ARUBA_CORVINA (7)
    Jan 22 22:34:50  KERNEL: 0:<5>511MB HIGHMEM available.
    Jan 22 22:34:50  KERNEL: 0:<7>On node 0 totalpages: 262112
    Jan 22 22:34:50  KERNEL: 0:<7>  DMA zone: 131072 pages, LIFO batch:31
    Jan 22 22:34:50  KERNEL: 0:<7>  DMA32 zone: 0 pages, LIFO batch:0
    Jan 22 22:34:50  KERNEL: 0:<7>  Normal zone: 0 pages, LIFO batch:0
    Jan 22 22:34:50  KERNEL: 0:<7>  HighMem zone: 131040 pages, LIFO batch:31
    Jan 22 22:34:50  KERNEL: 0:(PROM) CPU present map: f SOS_CPU_MAP: 0xf0 online CPUs: 0xff cli_cpu:4
    Jan 22 22:34:50  KERNEL: 0:Phys CPU present map: f, possible map f
    Jan 22 22:34:50  KERNEL: 0:Detected 3 Slave CPU(s)
    Jan 22 22:34:50  KERNEL: 0:<6>LTT : ltt-base init
    Jan 22 22:34:50  KERNEL: 0:Primary instruction cache 32kB, 8-way, linesize 32 bytes.
    Jan 22 22:34:50  KERNEL: 0:Primary data cache 32kB 8-way, linesize 32 bytes.
    Jan 22 22:34:50  KERNEL: 0:Setting up NMI Handler for Axxx platforms
    Jan 22 22:34:50  KERNEL: 0:mips_hpt_frequency = 733000000
    Jan 22 22:34:50  KERNEL: 0:Using 733.000 MHz high precision timer. cycles_per_jiffy=7330000
    Jan 22 22:34:50  KERNEL: 0:phoenix_timer_setup: non_core_cpus:3 Maxval:3640e mask:e
    Jan 22 22:34:50  KERNEL: 0:phoenix_timer_setup: phoenix_timer_stats = 84004a20, phoenix_timer_diff = 84004a40,
    Jan 22 22:34:50  KERNEL:     phoenix_timer_count = 84004a60, phoenix_timer_epc = 84004a80,
    Jan 22 22:34:50  KERNEL:     phoenix_timer_cpu = 84004aa0, phoenix_timer_gettimeoffset = 84004ac0
    Jan 22 22:34:50  KERNEL:     max_val[0] = a2c2a, max_val[others] = 3640e,
    Jan 22 22:34:50  KERNEL: 0:<6>Memory: 701064k/252416k available (4154k kernel code, 74788k reserved, 860k data, 59508k init, 524160k highmem)
    Jan 22 22:34:50  KERNEL: 0:<7>Calibrating delay loop... 0:167.11 BogoMIPS (lpj=835584)
    Jan 22 22:34:50  KERNEL: 0:<6>Security Framework v1.0.0 initialized
    Jan 22 22:34:50  KERNEL: 0:<6>Capability LSM initialized
    Jan 22 22:34:50  KERNEL: 0: available.
    Jan 22 22:34:50  KERNEL: 0:(PROM): waking up phys cpu# 1, bucket_1, gp = 84ace000
    Jan 22 22:34:50  KERNEL: 0:(PROM): sent a wakeup message to bucket 1
    Jan 22 22:34:50  KERNEL: 1:Initializing CPU:0 (1), current=84ab4048, gp = 84ace000
    Jan 22 22:34:50  KERNEL: 1:<7>Calibrating delay loop... 1:173.67 BogoMIPS (lpj=868352)
    Jan 22 22:34:50  KERNEL: 1:<7>Calibrating delay loop... 1:173.26 BogoMIPS (lpj=866304)
    Jan 22 22:34:50  KERNEL: 0:(PROM): waking up phys cpu# 2, bucket_2, gp = 84af6000
    Jan 22 22:34:50  KERNEL: 0:(PROM): sent a wakeup message to bucket 2
    Jan 22 22:34:50  KERNEL: 2:Initializing CPU:0 (2), current=84abb028, gp = 84af6000
    Jan 22 22:34:50  KERNEL: 2:<7>Calibrating delay loop... 2:247.39 BogoMIPS (lpj=1236992)
    Jan 22 22:34:50  KERNEL: 0:(PROM): waking up phys cpu# 3, bucket_3, gp = 84afe000
    Jan 22 22:34:50  KERNEL: 0:(PROM): sent a wakeup message to bucket 3
    Jan 22 22:34:50  KERNEL: 3:Initializing CPU:0 (3), current=84ad4048, gp = 84afe000
    Jan 22 22:34:50  KERNEL: 3:<7>Calibrating delay loop... 3:374.37 BogoMIPS (lpj=1871872)
    Jan 22 22:34:50  KERNEL: 0:<6>Brought up 4 CPUs
    Jan 22 22:34:50  KERNEL: 1:migration_cost=1:100001:
    Jan 22 22:34:50  KERNEL: 0:<5>detected lzma initramfs
    Jan 22 22:34:50  KERNEL: 0:<5>initramfs: LZMA lc=3,lp=0,pb=2,dictSize=8388608,origSize=165816832
    Jan 22 22:34:50  KERNEL: :.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0
    Jan 22 22:34:50  KERNEL: 0:<6>Initializing Aruba nodeinfo Netlink Socket
    Jan 22 22:34:50  KERNEL: 0:[pcibios_init]: IO-Remapped phys=10000000, size=1000000 to vaddr=b0000000
    Jan 22 22:34:50  KERNEL: 0:[pcibios_init]: IO-Remapped phys=15000000, size=100000 to vaddr=b5000000
    Jan 22 22:34:50  KERNEL: 0:Registering XLR/XLS PCIX/PCIE Controller.
    Jan 22 22:34:50  KERNEL: 0:<5>SCSI subsystem initialized
    Jan 22 22:34:50  KERNEL: 0:<6>LTT : ltt-facilities init
    Jan 22 22:34:50  KERNEL: 0:<6>LTT : ltt-heartbeat init
    Jan 22 22:34:50  KERNEL: 0:highmem bounce pool size: 64 pages
    Jan 22 22:34:50  KERNEL: 0:<6>LTT : ltt-facility-core init in kernel
    Jan 22 22:34:50  KERNEL: 0:<6>LTT : ltt-facility-fs init in kernel
    Jan 22 22:34:50  KERNEL: 0:<6>LTT : ltt-facility-ipc init in kernel
    Jan 22 22:34:50  KERNEL: 0:<6>LTT : ltt-facility-kernel_arch init in kernel
    Jan 22 22:34:50  KERNEL: 0:<6>LTT : ltt-facility-kernel init in kernel
    Jan 22 22:34:50  KERNEL: 0:<6>LTT : ltt-facility-locking init in kernel
    Jan 22 22:34:50  KERNEL: 0:<6>LTT : ltt-facility-memory init in kernel
    Jan 22 22:34:50  KERNEL: 0:<6>LTT : ltt-facility-network init in kernel
    Jan 22 22:34:50  KERNEL: 0:<6>LTT : ltt-facility-process init in kernel
    Jan 22 22:34:50  KERNEL: 0:<6>LTT : ltt-facility-socket init in kernel
    Jan 22 22:34:50  KERNEL: 0:<6>LTT : ltt-facility-timer init in kernel
    Jan 22 22:34:50  KERNEL: 0:<6>LTT : ltt-facility-statedump init in kernel
    Jan 22 22:34:50  KERNEL: 0:<6>LTT : ltt-facility-network_ip_interface init in kernel
    Jan 22 22:34:50  KERNEL: 0:<6>LTT : ltt-core init as module
    Jan 22 22:34:50  KERNEL: 0:<6>ltt-control init
    Jan 22 22:34:50  KERNEL: 0:<6>hw_random hardware driver 1.0.0 loaded
    Jan 22 22:34:50  KERNEL: 0:Registered XLR tracebuffer driver with Major No. [0]
    Jan 22 22:34:50  KERNEL: 0:[drivers/char/xlrinfo/xlrinfo.c@419|xlrinfo_init]: cpu_0: xlrinfo_init: BEGIN RMIINFO_INIT
    Jan 22 22:34:50  KERNEL: 0:Registered sos console serial driver
    Jan 22 22:34:50  KERNEL: 0:Coredump handling done by CPU3
    Jan 22 22:34:50  KERNEL: 0:upic initialization done
    Jan 22 22:34:50  KERNEL: 0:System time change notify driver inited
    Jan 22 22:34:50  KERNEL: 0:Function [virtual_uart_init]Loader support not enabled. Returning from virtual_uart_init
    Jan 22 22:34:50  KERNEL: 0:RAMDISK driver initialized: 16 RAM disks of 87040K size 1024 blocksize
    Jan 22 22:34:50  KERNEL: 0:[user_mac_init]: user_mac_data=0x52ed28, psb_shm_size=0x800000
    Jan 22 22:34:50  KERNEL: 0:Registered phoenix user_mac driver: major=0
    Jan 22 22:34:50  KERNEL: 0:[drivers/net/sos_msg.c@3875|sos_msg_init_module]: cpu_0: Registering sos_msg_driver
    Jan 22 22:34:50  KERNEL: ask:0xe0 from 1 to 2
    Jan 22 22:34:50  KERNEL: 0:rtgw_tunnel_init
    Jan 22 22:34:50  KERNEL: 0:stacking interface driver 0:inited
    Jan 22 22:34:50  KERNEL: 0:Loopback interface driver inited
    Jan 22 22:34:50  KERNEL: 0:<6>PPP generic driver version 2.4.2
    Jan 22 22:34:50  KERNEL: 0:<6>PPP Deflate Compression module registered
    Jan 22 22:34:50  KERNEL: 0:<6>PPP BSD Compression module registered
    Jan 22 22:34:50  KERNEL: 0:<5>physmap flash device: 1000000 at 1c000000
    Jan 22 22:34:50  KERNEL: 0:<6>phys_mapped_flash: Found 1 x16 devices at 0x0 in 8-bit bank
    Jan 22 22:34:50  KERNEL: 0: Amd/Fujitsu Extended Query Table at 0x0040
    Jan 22 22:34:50  KERNEL: 0:<4>phys_mapped_flash: CFI does not contain boot bank location. Assuming top.
    Jan 22 22:34:50  KERNEL: 0:<5>number of CFI chips: 1
    Jan 22 22:34:50  KERNEL: 0:Parsing the partition  info
    Jan 22 22:34:50  KERNEL: 0:Adding partitions...
    Jan 22 22:34:50  KERNEL: 0:<5>Using physmap partition definition
    Jan 22 22:34:50  KERNEL: 0:<5>Creating 2 MTD partitions on "phys_mapped_flash":
    Jan 22 22:34:50  KERNEL: 0:<5>0x00000000-0x00220000 : "bootROM"
    Jan 22 22:34:50  KERNEL: 0:<5>0x00220000-0x00800000 : "nvram-eeprom"
    Jan 22 22:34:50  KERNEL: 0:<6>ehci-xls ehci-xls.0: XLS EHCI Host Controller
    Jan 22 22:34:50  KERNEL: 0:<6>ehci-xls ehci-xls.0: new USB bus registered, assigned bus number 1
    Jan 22 22:34:50  KERNEL: 0:<6>ehci-xls ehci-xls.0: irq 39, io mem 0x1ef24000
    Jan 22 22:34:50  KERNEL: 0:<6>ehci-xls ehci-xls.0: USB 0.0 started, EHCI 1.00, driver 10 Dec 2004
    Jan 22 22:34:50  KERNEL: 0:USB Device: 0x00000000
    Jan 22 22:34:50  KERNEL: 0:USB Product: XLS EHCI Host Controller
    Jan 22 22:34:50  KERNEL: 0:USB Manufacturer: Linux 2.6.16 ehci_hcd
    Jan 22 22:34:50  KERNEL: 0:USB SerialNumber: ehci-xls
    Jan 22 22:34:50  KERNEL: 0:<6>usb usb1: c->desc.bMaxPower 0, udev->busmA 0
    Jan 22 22:34:50  KERNEL: 0:<6>usb usb1: configuration #1 chosen from 1 choice
    Jan 22 22:34:50  KERNEL: 0:<6>hub 1-0:1.0: USB hub found
    Jan 22 22:34:50  KERNEL: 0:<6>hub 1-0:1.0: 2 ports detected
    Jan 22 22:34:50  KERNEL: 0:<7>ohci_hcd: 2005 April 22 USB 1.1 'Open' Host Controller (OHCI) Driver (PCI)
    Jan 22 22:34:50  KERNEL: 0:<6>ohci-xls ohci-xls.1: XLS OHCI Host Controller
    Jan 22 22:34:50  KERNEL: 0:<6>ohci-xls ohci-xls.1: new USB bus registered, assigned bus number 2
    Jan 22 22:34:50  KERNEL: 0:<6>ohci-xls ohci-xls.1: irq 39, io mem 0x1ef24400
    Jan 22 22:34:50  KERNEL: 0:USB Product: XLS OHCI Host Controller
    Jan 22 22:34:50  KERNEL: 0:USB Manufacturer: Linux 2.6.16 ohci_hcd
    Jan 22 22:34:50  KERNEL: 0:USB SerialNumber: ohci-xls
    Jan 22 22:34:50  KERNEL: 0:<6>usb usb2: c->desc.bMaxPower 0, udev->busmA 0
    Jan 22 22:34:50  KERNEL: 0:<6>usb usb2: configuration #1 chosen from 1 choice
    Jan 22 22:34:50  KERNEL: 0:<6>hub 2-0:1.0: USB hub found
    Jan 22 22:34:50  KERNEL: 0:<6>hub 2-0:1.0: 1 port detected
    Jan 22 22:34:50  KERNEL: 0:<6>ohci-xls ohci-xls.2: XLS OHCI Host Controller
    Jan 22 22:34:50  KERNEL: 0:<6>ohci-xls ohci-xls.2: new USB bus registered, assigned bus number 3
    Jan 22 22:34:50  KERNEL: 0:<6>ohci-xls ohci-xls.2: irq 39, io mem 0x1ef24800
    Jan 22 22:34:50  KERNEL: 0:<6>usb usb3: c->desc.bMaxPower 0, udev->busmA 0
    Jan 22 22:34:50  KERNEL: 0:<6>usb usb3: configuration #1 chosen from 1 choice
    Jan 22 22:34:50  KERNEL: 0:<6>hub 3-0:1.0: USB hub found
    Jan 22 22:34:50  KERNEL: 0:<6>hub 3-0:1.0: 1 port detected
    Jan 22 22:34:50  KERNEL: 0:<6>USB Universal Host Controller Interface driver v2.3
    Jan 22 22:34:50  KERNEL: 0:<6>Initializing USB Mass Storage driver...
    Jan 22 22:34:50  KERNEL: 0:<6>usb 2-1: new full speed USB device using ohci-xls and address 2
    Jan 22 22:34:50  KERNEL: 0:<6>usb 2-1: not running at top speed; connect to a high speed hub
    Jan 22 22:34:50  KERNEL: 0:USB Device: 0x058f6387
    Jan 22 22:34:50  KERNEL: 0:USB Product: USB DISK
    Jan 22 22:34:50  KERNEL: 0:USB Manufacturer: SMI Corporation
    Jan 22 22:34:50  KERNEL: 0:USB SerialNumber: AA04012700014023
    Jan 22 22:34:50  KERNEL: 0:<6>usb 2-1: c->desc.bMaxPower 50, udev->busmA 500
    Jan 22 22:34:50  KERNEL: 0:<6>usb 2-1: configuration #1 chosen from 1 choice
    Jan 22 22:34:50  KERNEL: 0:<6>scsi0 : SCSI emulation for USB Mass Storage devices
    Jan 22 22:34:50  KERNEL: 0:<6>USB Mass Storage support registered.
    Jan 22 22:34:50  KERNEL: 0:Intializing I2C Host Adapter...0:done.
    Jan 22 22:34:50  KERNEL: 0:<7>usb-storage: device found at 2
    Jan 22 22:34:50  KERNEL: 0:<7>usb-storage: waiting for device to settle before scanning
    Jan 22 22:34:50  KERNEL: 0:i2c-palm-bk3220: Added I2C Bus 0
    Jan 22 22:34:50  KERNEL: 0:i2c-palm-bk3220: Added I2C Bus 1
    Jan 22 22:34:50  KERNEL: 0:<6>i2c-corvina: using default base 0xbef18000
    Jan 22 22:34:50  KERNEL: 0:isl1221_init: skipping isl1221 rtc initialization
    Jan 22 22:34:50  KERNEL: 0:<6>m41t11 3-0068: Found M41T11 RTC on Virtual I2C (i2c-0, mux 70:00) at 68
    Jan 22 22:34:50  KERNEL: 0:<6>eeprom 4-0050: Found eeprom on Virtual I2C (i2c-0, mux 70:01) at 50
    Jan 22 22:34:50  KERNEL: 0:<6>eeprom 5-0050: Found eeprom on Virtual I2C (i2c-0, mux 70:02) at 50
    Jan 22 22:34:50  KERNEL: 0:<6>eeprom 6-0052: Found eeprom on Virtual I2C (i2c-0, mux 70:03) at 52
    Jan 22 22:34:50  KERNEL: 0:<6>eeprom 7-0050: Found eeprom on Virtual I2C (i2c-0, mux 70:04) at 50
    Jan 22 22:34:50  KERNEL: 0:<6>eeprom 7-0051: Found eeprom on Virtual I2C (i2c-0, mux 70:04) at 51
    Jan 22 22:34:50  KERNEL: 0:<6>eeprom 7-0053: Found eeprom on Virtual I2C (i2c-0, mux 70:04) at 53
    Jan 22 22:34:50  KERNEL: 0:<6>eeprom 7-0056: Found eeprom on Virtual I2C (i2c-0, mux 70:04) at 56
    Jan 22 22:34:50  KERNEL: Found eeprom on Virtual I2C (i2c-0, mux 70:05) at 50
    Jan 22 22:34:50  KERNEL: 0:<6>eeprom 8-0051: Found eeprom on Virtual I2C (i2c-0, mux 70:05) at 51
    Jan 22 22:34:50  KERNEL: 0:<6>eeprom 8-0053: Found eeprom on Virtual I2C (i2c-0, mux 70:05) at 53
    Jan 22 22:34:50  KERNEL: 0:<6>eeprom 8-0056: Found eeprom on Virtual I2C (i2c-0, mux 70:05) at 56
    Jan 22 22:34:50  KERNEL: 0:<6>eeprom 9-0050: Found eeprom on Virtual I2C (i2c-0, mux 70:06) at 50
    Jan 22 22:34:50  KERNEL: 0:<6>eeprom 9-0051: Found eeprom on Virtual I2C (i2c-0, mux 70:06) at 51
    Jan 22 22:34:50  KERNEL: 0:<6>eeprom 9-0053: Found eeprom on Virtual I2C (i2c-0, mux 70:06) at 53
    Jan 22 22:34:50  KERNEL: 0:<6>eeprom 9-0056: Found eeprom on Virtual I2C (i2c-0, mux 70:06) at 56
    Jan 22 22:34:50  KERNEL: 0:<6>eeprom 10-0050: Found eeprom on Virtual I2C (i2c-0, mux 70:07) at 50
    Jan 22 22:34:50  KERNEL: 0:<6>eeprom 10-0051: Found eeprom on Virtual I2C (i2c-0, mux 70:07) at 51
    Jan 22 22:34:50  KERNEL: 0:<6>eeprom 10-0053: Found eeprom on Virtual I2C (i2c-0, mux 70:07) at 53
    Jan 22 22:34:50  KERNEL: 0:<6>eeprom 10-0056: Found eeprom on Virtual I2C (i2c-0, mux 70:07) at 56
    Jan 22 22:34:50  KERNEL: 0:<6>pca954x 0-0070: Registered 8 virtual busses for I2C switch pca9548
    Jan 22 22:34:50  KERNEL: 0:<6>i2c_adapter i2c-1: pca954x not found or failed to read reg at 0x71
    Jan 22 22:34:50  KERNEL: 0:<6>i2c_adapter i2c-1: pca954x not found or failed to read reg at 0x72
    Jan 22 22:34:50  KERNEL: 0:<6>i2c_adapter i2c-1: pca954x not found or failed to read reg at 0x73
    Jan 22 22:34:50  KERNEL: 0:Registering Phoenix I2C based TPM driver...
    Jan 22 22:34:50  KERNEL: 0:<6>w83793 9-002d: Found W83793 on Virtual I2C (i2c-0, mux 70:06) at 2d
    Jan 22 22:34:50  KERNEL: 0:<6>lm75 6-0048: Found LM75 on Virtual I2C (i2c-0, mux 70:03) at 48
    Jan 22 22:34:50  KERNEL: 0:<6>lm75 8-0048: Found LM75 on Virtual I2C (i2c-0, mux 70:05) at 48
    Jan 22 22:34:50  KERNEL: 0:<6>lm75 8-0049: Found LM75 on Virtual I2C (i2c-0, mux 70:05) at 49
    Jan 22 22:34:50  KERNEL: 0:<6>lm75 8-004a: Found LM75 on Virtual I2C (i2c-0, mux 70:05) at 4a
    Jan 22 22:34:50  KERNEL: 0:<6>lo: Disabled Privacy Extensions
    Jan 22 22:34:50  KERNEL: 0:<6>IPv6 over IPv4 tunneling driver
    Jan 22 22:34:50  KERNEL: 0:<6>802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
    Jan 22 22:34:50  KERNEL: 0:<6>All bugs added by David S. Miller <davem@redhat.com>
    Jan 22 22:34:50  KERNEL: 0:<5>  Vendor: 0:S0:M0:I0: 0: 0: 0: 0: 0:  Model: 0:U0:S0:B0: 0:D0:I0:S0:K0: 0: 0: 0: 0: 0: 0: 0: 0:  Rev: 0:10:10:00:00:
    Jan 22 22:34:50  KERNEL: 0:<5>  Type:   Direct-Access     0:                 ANSI SCSI revision: 000:
    Jan 22 22:34:50  KERNEL: 0:<5>SCSI device sda: 1957888 512-byte hdwr sectors (1002 MB)
    Jan 22 22:34:50  KERNEL: 0:<5>sda: Write Protect is off
    Jan 22 22:34:50  KERNEL: 0:<7>sda: Mode Sense: 43 00 00 00
    Jan 22 22:34:50  KERNEL: 0:<3>sda: assuming drive cache: write through
    Jan 22 22:34:50  KERNEL: 0:<6> sda:0: sda10: sda20: sda30:
    Jan 22 22:34:50  KERNEL: 0:<5>sd 0:0:0:0: Attached scsi disk sda
    Jan 22 22:34:50  KERNEL: 0:<7>usb-storage: device scan complete
    Jan 22 22:34:50  KERNEL: 3:<6>kjournald starting.  Commit interval 5 seconds
    Jan 22 22:34:50  KERNEL: 3:<6>EXT3 FS on sda3, 3:internal journal
    Jan 22 22:34:50  KERNEL: 3:<6>EXT3-fs: mounted filesystem with ordered data mode.
    Jan 22 22:34:50  KERNEL: 3:<3>aruba_n_nl_rcv_msg: passed module #(1) doesn't match with registered one(0)
    Jan 22 22:34:50  KERNEL: 3:<3>aruba_n_nl_rcv_msg: passed module #(3) doesn't match with registered one(0)
    Jan 22 22:34:50  KERNEL: 3:<4>process `syslogd' is using obsolete setsockopt SO_BSDCOMPAT
    Jan 22 22:34:50  KERNEL: 3:Send 3 start
    Jan 22 22:34:50  KERNEL: 3:Send 2 start
    Jan 22 22:34:50  KERNEL: 3:Send 1 start
    Jan 22 22:34:50  KERNEL: 3:TPM driver running in 3204 mode
    Jan 22 22:34:51  KERNEL: 0:<3>aruba_n_nl_rcv_msg: passed module #(1) doesn't match with registered one(0)
    Jan 22 22:34:51  KERNEL: 3:<3>aruba_n_nl_rcv_msg: passed module #(1) doesn't match with registered one(0)
    Jan 22 22:34:51  KERNEL: 2:<6>aruba_n_nl_rcv_msg: Registering module(3), buffer len:82
    Jan 22 22:34:51  KERNEL: 2:<6>aruba_n_nl_rcv_msg: Registered a new module(3), buffer len(82)
    Jan 22 22:34:52  KERNEL: 3:<3>aruba_n_nl_rcv_msg: passed module #(1) doesn't match with registered one(0)
    Jan 22 22:34:53  KERNEL: 2:eth1.4095: Setting MAC address to 2: 002: 0b2: 862: 012: 002: 002:.
    Jan 22 22:34:53  KERNEL: 2:VLAN (eth1.4095):  Setting underlying device (eth1) to promiscious mode.
    Jan 22 22:34:53  KERNEL: 1:<6>aruba_n_nl_rcv_msg: Registering module(1), buffer len:9
    Jan 22 22:34:53  KERNEL: 1:<6>aruba_n_nl_rcv_msg: Registered a new module(1), buffer len(9)
    Jan 22 22:34:53 :399816:  <ERRS> |dpa|  mrvl_init_new_dev: /dev/ppe0 not found. Marvel Device initialization failed
    Jan 22 22:34:54  KERNEL: 0:0 do_newlink
    Jan 22 22:34:54  KERNEL: 0:1 do_newlink
    Jan 22 22:35:00 :303073:  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 1431] died: got signal SIGABRT
    Jan 22 22:35:00 :303080:  <ERRS> |nanny|  Please tar and email the file crash.tar to support@arubanetworks.com
    Jan 22 22:35:00 :303081:  <ERRS> |nanny| To tar type the following commands at the Command Line Interface: (1) tar crash (2) copy flash: crash.tar tftp: [serverip] [destn filename]
    Jan 22 22:35:03 :303029:  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 1431]: crash data saved in dir /flash//crash/process/1-22-2019@22-35-00/dpa@1431
    Jan 22 22:35:03 :303025:  <ERRS> |nanny|  Found core file /tmp/core.1431.dpa.S2500_65516, 24412160 bytes, compressing...
    Jan 22 22:35:22  KERNEL: 1:<6>aruba_n_nl_rcv_msg: GET data request for module's(1), buffer len=9
    Jan 22 22:35:22  KERNEL: 1:<6>aruba_n_nl_rcv_msg: GET data request for module's(3), buffer len=82
    Jan 22 22:35:25  KERNEL: 0:<6>aruba_n_nl_rcv_msg: GET data request for module's(1), buffer len=9
    Jan 22 22:35:27 :341508:  <WARN> |stackmgr|  stack-manager mac-persist timer changed to 15
    Jan 22 22:35:27 :341507:  <WARN> |stackmgr|  stack-manager election-priority for member 0 changed to:128
    Jan 22 22:35:30 :303079:  <ERRS> |nanny|  Restarted process /mswitch/bin/dpa, new pid 2819
    Jan 22 22:35:31  KERNEL: 3:<6>aruba_n_nl_rcv_msg: GET data request for module's(1), buffer len=9
    Jan 22 13:35:33 :399816:  <ERRS> |dpa|  mrvl_init_new_dev: /dev/ppe0 not found. Marvel Device initialization failed
    Jan 22 22:35:38 :341533:  <WARN> |stackmgr|  Member 00:0b:86:a5:41:00 has Connected
    Jan 22 13:35:38  KERNEL: 1:<6>aruba_n_nl_rcv_msg: Setting module's(1) buffer. Len of buffer=9
  • 10.  RE: Aruba S2500-24P stack problem
    Posted Jan 22, 2019 05:01 PM
    Jan 22 13:35:38 :341529:  <WARN> |stackmgr|  Role changed from Init to Primary for 00:0b:86:a5:41:00
    Jan 22 13:35:39 :341531:  <WARN> |stackmgr|  Primary member-id changed from 255 to 0 for 00:0b:86:a5:41:00
    Jan 22 22:35:39 :399816:  <ERRS> |nanny|  Terminating process /mswitch/bin/profmgr, pid 1415
    Jan 22 13:35:39 :399816:  <ERRS> |nanny|  Terminating process /mswitch/bin/udbserver, pid 1417
    Jan 22 13:35:39 :399816:  <ERRS> |nanny|  Terminating process /mswitch/bin/ntpwrap, pid 1419
    Jan 22 13:35:39 :399803:  <ERRS> |stackmgr|  An internal system error has occurred: error recv returned 0, expecting 5.
    Jan 22 13:35:39 :399803:  <ERRS> |stackmgr|  An internal system error has occurred: error ncfg_profmgr_task_based_error_handler:Profile manager most probably died, context:0x100006b8. Handling error for task-based app and resyncing with profile-manager.
    Jan 22 13:35:39  KERNEL: 1:<6>aruba_n_nl_rcv_msg: Setting module's(1) buffer. Len of buffer=9
    Jan 22 13:35:39  KERNEL: 0:0 do_newlink
    Jan 22 13:35:39  KERNEL: 0:1 do_newlink
    Jan 22 13:35:41 :341535:  <WARN> |stackmgr|  System Mac-address changed from 00:00:00:00:00:00 to 00:0b:86:a5:41:00
    Jan 22 13:35:41 :303073:  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 2819] died: got signal SIGABRT
    Jan 22 13:35:43 :399803:  <ERRS> |im|  An internal system error has occurred: error Unable to connect to profmgr: Connection refused.
    Jan 22 13:35:43 :330006:  <ERRS> |im|  Connection failure with profile manager, Unable to connect to profmgr
    Jan 22 13:35:43 :399803:  <ERRS> |im|  An internal system error has occurred: error ncfg_gated_profmgr_connect:ERROR: ncfg_init failed:14.
    Jan 22 13:35:43 :341536:  <WARN> |stackmgr|  System active management port member-id changed from 0 to 255
    Jan 22 13:35:44  KERNEL: 1:<6>aruba_n_nl_rcv_msg: GET data request for module's(1), buffer len=9
    Jan 22 13:35:44 :303080:  <ERRS> |nanny|  Please tar and email the file crash.tar to support@arubanetworks.com
    Jan 22 13:35:44 :303081:  <ERRS> |nanny| To tar type the following commands at the Command Line Interface: (1) tar crash (2) copy flash: crash.tar tftp: [serverip] [destn filename]
    Jan 22 13:35:44  KERNEL: 3:<6>aruba_n_nl_rcv_msg: GET data request for module's(1), buffer len=9
    Jan 22 13:35:44 :399803:  <ERRS> |stackmgr|  An internal system error has occurred: error Unable to connect to profmgr: Connection refused.
    Jan 22 13:35:44 :330006:  <ERRS> |stackmgr|  Connection failure with profile manager, Unable to connect to profmgr
    Jan 22 13:35:44 :399803:  <ERRS> |stackmgr|  An internal system error has occurred: error ncfg_task_based_profmgr_reconnect:Unable to reconnect with profile-manager. Setting task timer to 5.
    Jan 22 13:35:44  KERNEL: 2:<6>aruba_n_nl_rcv_msg: Setting module's(3) buffer. Len of buffer=82
    Jan 22 13:35:45  KERNEL: 0:<6>aruba_n_nl_rcv_msg: GET data request for module's(1), buffer len=9
    Jan 22 13:35:45 :399803:  <ERRS> |profmgr|  An internal system error has occurred: error Our role is MASTER, re-syncing with certificate-manager .
    Jan 22 13:35:46 :306510:  <WARN> |publisher|  Dropping message from 8214 for service 'aaa-idle-user-timeout (service not found)'
    Jan 22 13:35:46 :340009:  <WARN> |l2m| Spanning tree mode is MSTP
    Jan 22 13:35:49 :303029:  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 2819]: crash data saved in dir /flash//crash/process/1-22-2019@13-35-44/dpa@2819
    Jan 22 13:35:49 :303025:  <ERRS> |nanny|  Found core file /tmp/core.2819.dpa.S2500_65516, 24412160 bytes, compressing...
    Jan 22 13:35:49 :399803:  <ERRS> |stackmgr|  An internal system error has occurred: error ncfg_task_based_profmgr_reconnect:Connection to profile-manager established, setting socket..
    Jan 22 13:35:50  KERNEL: 3:<4>process `snmpd' is using obsolete setsockopt SO_BSDCOMPAT
    Jan 22 13:35:50 :306510:  <WARN> |publisher|  Dropping message from 8214 for service 'nat-pool (service not found)'
    Jan 22 13:35:52  KERNEL: 2:<6>aruba_n_nl_rcv_msg: GET data request for module's(3), buffer len=82
    Jan 22 13:35:52 :307500:  <ERRS> |cfgm|  Setting to send CFGM Init to EWS 4104
    Jan 22 13:35:56  KERNEL: 1:<6>aruba_n_nl_rcv_msg: GET data request for module's(3), buffer len=82
    Jan 22 13:35:57  KERNEL: 1:<6>aruba_n_nl_rcv_msg: Setting module's(3) buffer. Len of buffer=82
    Jan 22 13:35:57 :335308:  <ALRT> |ChassisManager|  ArubaS2500-24P detected on slot 0
    Jan 22 13:35:57 :335309:  <ALRT> |ChassisManager|  Power supply  detected on slot 0
    Jan 22 13:35:57 :335311:  <WARN> |ChassisManager|  Configuration parameters under enet profile (default) does not match for interface GE0/1/1, Ignoring the configuration
    Jan 22 13:35:57 :335311:  <WARN> |ChassisManager|  Configuration parameters under enet profile (default) does not match for interface GE0/1/0, Ignoring the configuration
    Jan 22 13:35:58  KERNEL: 1:<4>process `trapd' is using obsolete setsockopt SO_BSDCOMPAT
    Jan 22 13:36:23 :303079:  <ERRS> |nanny|  Restarted process /mswitch/bin/dpa, new pid 3670
    Jan 22 13:36:25 :399816:  <ERRS> |dpa|  mrvl_init_new_dev: /dev/ppe0 not found. Marvel Device initialization failed
    Jan 22 13:36:33 :303073:  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 3670] died: got signal SIGABRT
    Jan 22 13:36:34 :303080:  <ERRS> |nanny|  Please tar and email the file crash.tar to support@arubanetworks.com
    Jan 22 13:36:34 :303081:  <ERRS> |nanny| To tar type the following commands at the Command Line Interface: (1) tar crash (2) copy flash: crash.tar tftp: [serverip] [destn filename]
    Jan 22 13:36:37 :303029:  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 3670]: crash data saved in dir /flash//crash/process/1-22-2019@13-36-34/dpa@3670
    Jan 22 13:36:37 :303025:  <ERRS> |nanny|  Found core file /tmp/core.3670.dpa.S2500_65516, 24412160 bytes, compressing...
    Jan 22 13:36:54 :303079:  <ERRS> |nanny|  Restarted process /mswitch/bin/dpa, new pid 3859
    Jan 22 13:36:55 :399816:  <ERRS> |dpa|  mrvl_init_new_dev: /dev/ppe0 not found. Marvel Device initialization failed
    Jan 22 13:37:04 :303073:  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 3859] died: got signal SIGABRT
    Jan 22 13:37:04 :303080:  <ERRS> |nanny|  Please tar and email the file crash.tar to support@arubanetworks.com
    Jan 22 13:37:04 :303081:  <ERRS> |nanny| To tar type the following commands at the Command Line Interface: (1) tar crash (2) copy flash: crash.tar tftp: [serverip] [destn filename]
    Jan 22 13:37:07 :303029:  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 3859]: crash data saved in dir /flash//crash/process/1-22-2019@13-37-04/dpa@3859
    Jan 22 13:37:07 :303025:  <ERRS> |nanny|  Found core file /tmp/core.3859.dpa.S2500_65516, 24412160 bytes, compressing...
    Jan 22 13:37:13 :313523:  <ALRT> |im|  Autoconf disable message received from client port 8220
    Jan 22 13:37:24 :303079:  <ERRS> |nanny|  Restarted process /mswitch/bin/dpa, new pid 4061
    Jan 22 13:37:25 :399816:  <ERRS> |dpa|  mrvl_init_new_dev: /dev/ppe0 not found. Marvel Device initialization failed
    Jan 22 13:37:34 :303073:  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 4061] died: got signal SIGABRT
    Jan 22 13:37:34 :303080:  <ERRS> |nanny|  Please tar and email the file crash.tar to support@arubanetworks.com
    Jan 22 13:37:34 :303081:  <ERRS> |nanny| To tar type the following commands at the Command Line Interface: (1) tar crash (2) copy flash: crash.tar tftp: [serverip] [destn filename]
    Jan 22 13:37:37 :303029:  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 4061]: crash data saved in dir /flash//crash/process/1-22-2019@13-37-34/dpa@4061
    Jan 22 13:37:37 :303025:  <ERRS> |nanny|  Found core file /tmp/core.4061.dpa.S2500_65516, 24412160 bytes, compressing...
    Jan 22 13:37:54 :303079:  <ERRS> |nanny|  Restarted process /mswitch/bin/dpa, new pid 4256
    Jan 22 13:37:56 :399816:  <ERRS> |dpa|  mrvl_init_new_dev: /dev/ppe0 not found. Marvel Device initialization failed
    Jan 22 13:38:04 :303073:  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 4256] died: got signal SIGABRT
    Jan 22 13:38:04 :303080:  <ERRS> |nanny|  Please tar and email the file crash.tar to support@arubanetworks.com
    Jan 22 13:38:04 :303081:  <ERRS> |nanny| To tar type the following commands at the Command Line Interface: (1) tar crash (2) copy flash: crash.tar tftp: [serverip] [destn filename]
    Jan 22 13:38:07 :303029:  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 4256]: crash data saved in dir /flash//crash/process/1-22-2019@13-38-04/dpa@4256
    Jan 22 13:38:07 :303025:  <ERRS> |nanny|  Found core file /tmp/core.4256.dpa.S2500_65516, 24412160 bytes, compressing...
    Jan 22 13:38:24 :303079:  <ERRS> |nanny|  Restarted process /mswitch/bin/dpa, new pid 4447
    Jan 22 13:38:26 :399816:  <ERRS> |dpa|  mrvl_init_new_dev: /dev/ppe0 not found. Marvel Device initialization failed
    Jan 22 13:38:34 :303073:  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 4447] died: got signal SIGABRT
    Jan 22 13:38:34 :303080:  <ERRS> |nanny|  Please tar and email the file crash.tar to support@arubanetworks.com
    Jan 22 13:38:34 :303081:  <ERRS> |nanny| To tar type the following commands at the Command Line Interface: (1) tar crash (2) copy flash: crash.tar tftp: [serverip] [destn filename]
    Jan 22 13:38:37 :303029:  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 4447]: crash data saved in dir /flash//crash/process/1-22-2019@13-38-34/dpa@4447
    Jan 22 13:38:37 :303025:  <ERRS> |nanny|  Found core file /tmp/core.4447.dpa.S2500_65516, 24412160 bytes, compressing...
    Jan 22 13:38:54 :303079:  <ERRS> |nanny|  Restarted process /mswitch/bin/dpa, new pid 4638
    Jan 22 13:38:56 :399816:  <ERRS> |dpa|  mrvl_init_new_dev: /dev/ppe0 not found. Marvel Device initialization failed
    Jan 22 13:39:04 :303073:  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 4638] died: got signal SIGABRT
    Jan 22 13:39:04 :303080:  <ERRS> |nanny|  Please tar and email the file crash.tar to support@arubanetworks.com
    Jan 22 13:39:04 :303081:  <ERRS> |nanny| To tar type the following commands at the Command Line Interface: (1) tar crash (2) copy flash: crash.tar tftp: [serverip] [destn filename]
    Jan 22 13:39:08 :303029:  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 4638]: crash data saved in dir /flash//crash/process/1-22-2019@13-39-04/dpa@4638
    Jan 22 13:39:08 :303025:  <ERRS> |nanny|  Found core file /tmp/core.4638.dpa.S2500_65516, 24412160 bytes, compressing...
    Jan 22 13:37:27 :303079:  <ERRS> |nanny|  Restarted process /mswitch/bin/dpa, new pid 4845
    Jan 22 13:37:29 :399816:  <ERRS> |dpa|  mrvl_init_new_dev: /dev/ppe0 not found. Marvel Device initialization failed
    Jan 22 13:37:37 :303073:  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 4845] died: got signal SIGABRT
    Jan 22 13:37:37 :303080:  <ERRS> |nanny|  Please tar and email the file crash.tar to support@arubanetworks.com
    Jan 22 13:37:37 :303081:  <ERRS> |nanny| To tar type the following commands at the Command Line Interface: (1) tar crash (2) copy flash: crash.tar tftp: [serverip] [destn filename]
    Jan 22 13:37:41 :303029:  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 4845]: crash data saved in dir /flash//crash/process/1-22-2019@13-37-37/dpa@4845
    Jan 22 13:37:41 :303025:  <ERRS> |nanny|  Found core file /tmp/core.4845.dpa.S2500_65516, 24412160 bytes, compressing...
    Jan 22 13:37:43  KERNEL: 2:<6>aruba_n_nl_rcv_msg: Setting module's(3) buffer. Len of buffer=82
    Jan 22 13:37:57 :303079:  <ERRS> |nanny|  Restarted process /mswitch/bin/dpa, new pid 5082
    Jan 22 22:37:59 :399816:  <ERRS> |dpa|  mrvl_init_new_dev: /dev/ppe0 not found. Marvel Device initialization failed
    Jan 22 22:38:07 :303073:  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 5082] died: got signal SIGABRT
    Jan 22 22:38:07 :303080:  <ERRS> |nanny|  Please tar and email the file crash.tar to support@arubanetworks.com
    Jan 22 22:38:07 :303081:  <ERRS> |nanny| To tar type the following commands at the Command Line Interface: (1) tar crash (2) copy flash: crash.tar tftp: [serverip] [destn filename]
    Jan 22 22:38:11 :303029:  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 5082]: crash data saved in dir /flash//crash/process/1-22-2019@22-38-07/dpa@5082
    Jan 22 22:38:11 :303025:  <ERRS> |nanny|  Found core file /tmp/core.5082.dpa.S2500_65516, 24412160 bytes, compressing...
    Jan 22 22:38:28 :303079:  <ERRS> |nanny|  Restarted process /mswitch/bin/dpa, new pid 5273
    Jan 22 22:38:29 :399816:  <ERRS> |dpa|  mrvl_init_new_dev: /dev/ppe0 not found. Marvel Device initialization failed
    Jan 22 22:38:38 :303073:  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 5273] died: got signal SIGABRT
    Jan 22 22:38:38 :303080:  <ERRS> |nanny|  Please tar and email the file crash.tar to support@arubanetworks.com
    Jan 22 22:38:38 :303081:  <ERRS> |nanny| To tar type the following commands at the Command Line Interface: (1) tar crash (2) copy flash: crash.tar tftp: [serverip] [destn filename]
    Jan 22 22:38:41 :303029:  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 5273]: crash data saved in dir /flash//crash/process/1-22-2019@22-38-38/dpa@5273
    Jan 22 22:38:41 :303025:  <ERRS> |nanny|  Found core file /tmp/core.5273.dpa.S2500_65516, 24412160 bytes, compressing...
    Jan 22 22:38:58 :303079:  <ERRS> |nanny|  Restarted process /mswitch/bin/dpa, new pid 5468
    Jan 22 22:39:00 :399816:  <ERRS> |dpa|  mrvl_init_new_dev: /dev/ppe0 not found. Marvel Device initialization failed
    Jan 22 22:39:08 :303073:  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 5468] died: got signal SIGABRT
    Jan 22 22:39:08 :303080:  <ERRS> |nanny|  Please tar and email the file crash.tar to support@arubanetworks.com
    Jan 22 22:39:08 :303081:  <ERRS> |nanny| To tar type the following commands at the Command Line Interface: (1) tar crash (2) copy flash: crash.tar tftp: [serverip] [destn filename]
    Jan 22 22:39:11 :303029:  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 5468]: crash data saved in dir /flash//crash/process/1-22-2019@22-39-08/dpa@5468
    Jan 22 22:39:11 :303025:  <ERRS> |nanny|  Found core file /tmp/core.5468.dpa.S2500_65516, 24412160 bytes, compressing...
    Jan 22 22:39:28 :303079:  <ERRS> |nanny|  Restarted process /mswitch/bin/dpa, new pid 5659
    Jan 22 22:39:30 :399816:  <ERRS> |dpa|  mrvl_init_new_dev: /dev/ppe0 not found. Marvel Device initialization failed
    Jan 22 22:39:38 :303073:  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 5659] died: got signal SIGABRT
    Jan 22 22:39:38 :303080:  <ERRS> |nanny|  Please tar and email the file crash.tar to support@arubanetworks.com
    Jan 22 22:39:38 :303081:  <ERRS> |nanny| To tar type the following commands at the Command Line Interface: (1) tar crash (2) copy flash: crash.tar tftp: [serverip] [destn filename]
    Jan 22 22:39:42 :303029:  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 5659]: crash data saved in dir /flash//crash/process/1-22-2019@22-39-38/dpa@5659
    Jan 22 22:39:42 :303025:  <ERRS> |nanny|  Found core file /tmp/core.5659.dpa.S2500_65516, 24412160 bytes, compressing...
    Jan 22 22:39:58 :303079:  <ERRS> |nanny|  Restarted process /mswitch/bin/dpa, new pid 5853
    Jan 22 22:40:00 :399816:  <ERRS> |dpa|  mrvl_init_new_dev: /dev/ppe0 not found. Marvel Device initialization failed
    Jan 22 22:40:08 :303073:  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 5853] died: got signal SIGABRT
    Jan 22 22:40:08 :303080:  <ERRS> |nanny|  Please tar and email the file crash.tar to support@arubanetworks.com
    Jan 22 22:40:08 :303081:  <ERRS> |nanny| To tar type the following commands at the Command Line Interface: (1) tar crash (2) copy flash: crash.tar tftp: [serverip] [destn filename]
    Jan 22 22:40:12 :303029:  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 5853]: crash data saved in dir /flash//crash/process/1-22-2019@22-40-08/dpa@5853
    Jan 22 22:40:12 :303025:  <ERRS> |nanny|  Found core file /tmp/core.5853.dpa.S2500_65516, 24412160 bytes, compressing...
    Jan 22 22:40:29 :303079:  <ERRS> |nanny|  Restarted process /mswitch/bin/dpa, new pid 6044
    Jan 22 22:40:30 :399816:  <ERRS> |dpa|  mrvl_init_new_dev: /dev/ppe0 not found. Marvel Device initialization failed
    Jan 22 22:40:39 :303073:  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 6044] died: got signal SIGABRT
    Jan 22 22:40:39 :303080:  <ERRS> |nanny|  Please tar and email the file crash.tar to support@arubanetworks.com
    Jan 22 22:40:39 :303081:  <ERRS> |nanny| To tar type the following commands at the Command Line Interface: (1) tar crash (2) copy flash: crash.tar tftp: [serverip] [destn filename]
    Jan 22 22:40:42 :303029:  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 6044]: crash data saved in dir /flash//crash/process/1-22-2019@22-40-39/dpa@6044
    Jan 22 22:40:42 :303025:  <ERRS> |nanny|  Found core file /tmp/core.6044.dpa.S2500_65516, 24412160 bytes, compressing...
    Jan 22 22:40:59 :303079:  <ERRS> |nanny|  Restarted process /mswitch/bin/dpa, new pid 6235
    Jan 22 22:41:00 :399816:  <ERRS> |dpa|  mrvl_init_new_dev: /dev/ppe0 not found. Marvel Device initialization failed
    Jan 22 22:41:09 :303073:  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 6235] died: got signal SIGABRT
    Jan 22 22:41:09 :303080:  <ERRS> |nanny|  Please tar and email the file crash.tar to support@arubanetworks.com
    Jan 22 22:41:09 :303081:  <ERRS> |nanny| To tar type the following commands at the Command Line Interface: (1) tar crash (2) copy flash: crash.tar tftp: [serverip] [destn filename]
    Jan 22 22:41:12 :303029:  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 6235]: crash data saved in dir /flash//crash/process/1-22-2019@22-41-09/dpa@6235
    Jan 22 22:41:12 :303025:  <ERRS> |nanny|  Found core file /tmp/core.6235.dpa.S2500_65516, 24412160 bytes, compressing...
    Jan 22 22:41:29 :303079:  <ERRS> |nanny|  Restarted process /mswitch/bin/dpa, new pid 6426
    Jan 22 22:41:31 :399816:  <ERRS> |dpa|  mrvl_init_new_dev: /dev/ppe0 not found. Marvel Device initialization failed
    Jan 22 22:41:39 :303073:  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 6426] died: got signal SIGABRT
    Jan 22 22:41:39 :303080:  <ERRS> |nanny|  Please tar and email the file crash.tar to support@arubanetworks.com
    Jan 22 22:41:39 :303081:  <ERRS> |nanny| To tar type the following commands at the Command Line Interface: (1) tar crash (2) copy flash: crash.tar tftp: [serverip] [destn filename]
    Jan 22 22:41:42 :303029:  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 6426]: crash data saved in dir /flash//crash/process/1-22-2019@22-41-39/dpa@6426
    Jan 22 22:41:42 :303025:  <ERRS> |nanny|  Found core file /tmp/core.6426.dpa.S2500_65516, 24412160 bytes, compressing...
    Jan 22 22:41:59 :303079:  <ERRS> |nanny|  Restarted process /mswitch/bin/dpa, new pid 6617
    Jan 22 22:42:01 :399816:  <ERRS> |dpa|  mrvl_init_new_dev: /dev/ppe0 not found. Marvel Device initialization failed
    Jan 22 22:42:09 :303073:  <ERRS> |nanny|  Process /mswitch/bin/dpa [pid 6617] died: got signal SIGABRT
    Jan 22 22:42:09 :303080:  <ERRS> |nanny|  Please tar and email the file crash.tar to support@arubanetworks.com
    ports mgmt and GE0/0/0 are connected
    light on the port mgmt lit
    light on the port GE0/0/0 off
    (ArubaS2500-24P) #show interface brief
    Interface  Admin   Link  Line Protocol  Speed/Duplex
    GE0/0/0    Enable  Down  Down           N/A
    GE0/0/1    Enable  Down  Down           N/A
    GE0/0/2    Enable  Down  Down           N/A
    GE0/0/3    Enable  Down  Down           N/A
    GE0/0/4    Enable  Down  Down           N/A
    GE0/0/5    Enable  Down  Down           N/A
    GE0/0/6    Enable  Down  Down           N/A
    GE0/0/7    Enable  Down  Down           N/A
    GE0/0/8    Enable  Down  Down           N/A
    GE0/0/9    Enable  Down  Down           N/A
    GE0/0/10   Enable  Down  Down           N/A
    GE0/0/11   Enable  Down  Down           N/A
    GE0/0/12   Enable  Down  Down           N/A
    GE0/0/13   Enable  Down  Down           N/A
    GE0/0/14   Enable  Down  Down           N/A
    GE0/0/15   Enable  Down  Down           N/A
    GE0/0/16   Enable  Down  Down           N/A
    GE0/0/17   Enable  Down  Down           N/A
    GE0/0/18   Enable  Down  Down           N/A
    GE0/0/19   Enable  Down  Down           N/A
    GE0/0/20   Enable  Down  Down           N/A
    GE0/0/21   Enable  Down  Down           N/A
    GE0/0/22   Enable  Down  Down           N/A
    GE0/0/23   Enable  Down  Down           N/A
    GE0/1/0    Enable  Down  Down           N/A
    GE0/1/1    Enable  Down  Down           N/A
    MGMT       Enable  Down  Down           N/A
  • 11.  RE: Aruba S2500-24P stack problem
    Posted Jan 24, 2019 03:16 PM
    would anyone have an idea of what I should do.
