Environement: Aruba 2920 switches configured for 802.1x/MAB running 16.07. Not using User-Roles as there are restrictions preventing this.
When RADIUS Server fails to respond, I would like it to fallback to the VLANs already configured on the port. It does not appear there is an option to do so.
I can configure the UNAUTH VID however this is a Static VLAN.
The customer uses Static IP on all devices and has hard-coded specific VLANs on all ports. I am certainly working to get them off Static and use DHCP Reservations if statics are indeed needed. Until then, I am having a hard time coming up with a fallback mechanism in case Radius failure.
I could certainly set the UNAUTH VID to match the untagged VLAN but this would be extrememly combersome and time consuming to do this on every port in the network.
