Wired Intelligent Edge
Aruba switch constant memory usage rise
This thread has been viewed 16 times
  • 1.  Aruba switch constant memory usage rise
    Posted Sep 14, 2020 09:58 AM
    We have multiple Aruba switchs that seems to use more and more memory every days. We're afraid that they will crash if the memory usage reach 100% so we reboot them but since they're used 24h/24h, the customer isnt very happy about it. Is there any fix ?
    Thank you for your help.
  • 2.  RE: Aruba switch constant memory usage rise
    MVP GURU
    Posted Sep 14, 2020 11:26 AM
    Hello, are you able to provide little bit more details (Switch models, Switch running software versions, sanitized configurations, rate of memory usage increase over time, actual memory usage seen with usual show CLI command, etc.)?
  • 3.  RE: Aruba switch constant memory usage rise
    Posted Sep 14, 2020 12:27 PM
    Hello !
    Of course, I am eager to provide any useful information needed. The switch is a 2930M running on the ROM WC.17.02.0006. It seems that only one switch in the stack has this issue. Its memory is :
    Memory - Total   : 339,526,144
                    Free   : 32,901,976
    As for the other informations needed, can you assist me and tell me how to fetch them ?
    Thank you for your help !
  • 4.  RE: Aruba switch constant memory usage rise
    Posted Sep 14, 2020 12:43 PM
    Have you check which process use memory
    # show processes sort-by memory
    if any issue tries to update to the latest stable firmware. do you have any NMS system monitor this switch?
  • 5.  RE: Aruba switch constant memory usage rise
    MVP GURU
    Posted Sep 14, 2020 12:52 PM
    Hi! WC.17.02.0006 doesn't seem correct. Could you please verify again the software version (post the output of show flash and show version commends executed on your Aruba 2930M switch)?
  • 6.  RE: Aruba switch constant memory usage rise
    MVP GURU
    Posted Sep 14, 2020 12:53 PM
    Why do you believe the RAM used by your switch is "increasing" up to the point it will fill up? Is it an impression or have you seen a rate of increase?
  • 7.  RE: Aruba switch constant memory usage rise
    Posted Sep 14, 2020 01:08 PM
    Hello everyone,
    Here are the commands you asked for :
    As for the increase, I check it daily from a monitoring screen and just notice it's growing slowly. It could be an impression but I doubt it.
  • 8.  RE: Aruba switch constant memory usage rise
    Posted Sep 14, 2020 01:43 PM
    Try this. find output
    1. switch # process-tracking
    2. switch# task-monitor cpu
    3. switch# show cpu process
  • 9.  RE: Aruba switch constant memory usage rise
    Posted Sep 14, 2020 02:18 PM
    Greetings!
    I would first recommend upgrading the stack to the latest software release (WC.16.10.0010), and see if you observe the same behavior.
    Beyond that, when you say only one member of the stack is seeing this behavior, which member is it — the stack Commander, Standby, or one of the others?
  • 10.  RE: Aruba switch constant memory usage rise
    Posted Sep 15, 2020 08:46 AM
    Hello !
    Here's the result of the commands you asked for :
    The issue is on the stack commander.
  • 11.  RE: Aruba switch constant memory usage rise
    Posted Sep 28, 2020 07:35 AM
    Hi Ptranba,
    I am working in the Aruba ERT (L3) Engineering Escalation Team .
    Did you open a TAC case on this matter already?
    If so please post the case number here.
    If no TAC case is open already could you please do so?
    Just log in at https://asp.arubanetworks.com/ and you can create a case.
    Some short questions:
    1-Do you have any idea when the issue started? Software upgrade, new Networking Management Software  (NMS) deployed
    2-Do all of your switches exhibit this increasing memory usage?
    Could you attach a STA (Show Tech All) from an affected switch here please.
  • 12.  RE: Aruba switch constant memory usage rise
    Posted Sep 28, 2020 12:19 PM
    Hello Ardon,
    I didnt open a TAC case as since my account has been moved to the partner portal, I cannot connect anymore. I have an HPE ticket tho, does that count ? It's the 5350348534.
    As for your questions, we dont know since when the problem occur since when we start monitoring, the issue was still there.
    Many switchs exhibit this issue but not all of them.
