this is how you configure a global initial role:
(config)# aaa authorization user-role initial-role ROLE-STR
but how do you configure it at per-port level?
On page 262 Aruba 2540 Access Security Guide for ArubaOS-Switch 16.08 is just an indication that this is possible.
initial-role
The default initial role “denyall” is used when no other role applies. If a client connects to the switch and lacks a user role associated, then the initial role is used. Any role can be configured as initial role using this option.Initial role can be configured at per-port level. The per port initial role takes priority over global initial role.
Somehow I can't find any CLI reference guide for ArubaOS 16.08.
What is the command to configure it at a per-port level?
