Hi!
With regards to vsx update-software command for an orchestrated and sequenced VSX update I've a doubt...given the command's description provided on the CLI Guides:
Syntax
vsx update-software <REMOTE-URL> [vrf <VRF-NAME>]
Description
This command downloads new software from the TFTP server and verifies the download. After a successful verification, the command installs the software to the alternative image of both the VSX primary and secondary switches. The command then reboots them in sequence, the VSX secondary switch followed by VSX primary switch. For example if a switch has booted with the primary image, then the command will install the software to secondary image.
I'm asking if once the Secondary VSX node completes its reboot ("Secondary VSX system updated completely. Rebooting primary") will the outlined procedure above wait enough to let all node related VSX LAGs to be up and to collect/distribute again [*] before proceeding with the Primary VSX node?
[*] this should happen, if I'm not mistaken, at least after the linkup-delay timer that have been set expires.
