Highlighted
Frequent Contributor I
ArubaOS-CX on ESXI
has anybody deployed the ArubaOS-CX on ESXI with the OVA,
I am unable to get any connectivity to the management interface nor any of the other with some very simple config.
I have configured the mgmt interface with an IP and Default gateway, although unable to get a connection.
Am I missing something with the virtual deployment?
Highlighted
MVP Guru
Re: ArubaOS-CX on ESXI
Did you enable promiscuous mode on the virtual network connecting
the first interface of the VM (which is the mgmt interface) ?
Highlighted
 Yes, I tried that but no luck.
Highlighted
MVP Guru
could you paste a "show int mgmt" ?
Highlighted
had to do a screenshot, shows the config and no ip on the mgmt.
Highlighted
MVP Expert
Greetings!
Be sure to double-check the virtual NICs in the VM settings; in particular, Network Adapter 1 should be connected to the management network you wish to access the VM from using the virtual management interface.  If this is the first time you've started this virtual machine, try rebooting it using the boot system command, and check the management interface again.
Matt Fern
Senior Technical Marketing Engineer, Aruba Switching
Aruba, a Hewlett Packard Enterprise company
8000 FOOTHILLS BLVD  |  ROSEVILLE, CA 95747
T: 916.540.1759  |  E: mfern@hpe.com   |   Matt @ Twitter
Highlighted
I couldn't get this working, imported it into fusion and it works straight away.
Not how I wanted as wanted to use some of the features but will at least get me on the GUI and the Rest.
has anybody got it working on ESXI 6.5
Highlighted
MVP Guru
Yes. It works on ESXi6.5 and if you're a partner you can access OVA information on Arubapedia For Partners:
https://afp.arubanetworks.com/afp/index.php/ArubaOS-CX_OVA
https://afp.arubanetworks.com/afp/images/f/fa/ESXI_OVA_SETUP.pdf
Vincent
Highlighted
Thanks, Will have a read and see if I can get it working.
Highlighted
Contributor I
Has anyone had a chance to setup the ArubaOS-CX VM with GNS3 and have access to the GUI? if I set it up standalone with vmware player I can access the gui with no problem, but not with GNS3, seems that gns3 re arrange the ports overriding the my manual settings.
- Daniel Tudares (ACMA, ACSP)
