I have just received a 8320 (JL581A), and I am a complete n00b to anything beyond home networking. Someone will help set it up only weeks in the future, I'd like to get started with the basics now. Following the various documents available for this switch, i have not been able to achieve much. Can you advice on basic config?
Setup:
- single switch serving simple flat network, single vlan
- all devices on this network are in 192.168.1.1/24
- all destination IPs outside this range should be routed to 192.168.1.45, connected to if 1/1/1
- 192.168.1.45 is also DHCP and DNS server, clients connected to other ports should get an IP from this gateway
- to one of the ports an AP (345) will be connected, clients there should also be on 192.168.1.1/24 and get IP from DHCP server.
Just enabling a few ports (no shutdown) and connecting clients to that gets me nowhere). So i tried to assign those ports to vlan 1 (no routing, vlan access 1), which established connectivity, but no idea if thats what i should be doing. Still DHCP isn't served (it was for a bit, but forgot to persist configuration and was lost on reboot, even though i think i did the same by simple adding interfaces to vlan). I've been reading about L2 vs L3 networking, don't think i understand it, but don't want all traffic to be broadcasted to all devices of course (which i read happens in L2 mode?). Will try to verify with wireshark (if packets make it that far at least, no idea...)
So, whats the very basic setup I need to enable clients connected to any of the ports to receive an IP from DHCP at 192.168.1.45, for these clients to be able to communicate to each other point-to-point, and for traffic with destination IP outside 192.168.1.1/24 (or actually any traffic to an IP that isn't known locally) to be routed to 192.168.1.45?
Thanks very much for some hints on how to get started! I look forward to understanding this starting point and then learning further.
#8320
