Occasional Contributor I
Chrome and valid https certificate on switch GUI
Hi there,
Right now when we install a valid certificate on our switches (mostly 2530 and 2930F) Internet explorer is happy with how they look. Chrome however since 2017 doesn't like certificates with only a Common Name and no Subject Alternative Name. Unfortunately when requesting a certificate in the switch I don't have the options to enter a SAN. How do you guys fix this?
Best Regards,
Dieter
Re: Chrome and valid https certificate on switch GUI
The CA should be automatically adding the CN as a SAN. If they’re not, you should reach out to their support.
| Tim Cappalli | Aruba Security | @timcappalli | timcappalli.me |
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
