Config for 5400 series with NAC
Hi all,
I have some 5400 switches I’m going to use with certificate based NAC. I believe there is a procedure to link the switch with Clearpass and then configure to check for a certificate when a port is activated / plugged into?
So do you just need to give the switch a valid certificate from your CA? Can it contain multiple certificates from different CAs?
Any good links to help config this from Clearpass / switch end?
Re: Config for 5400 series with NAC
Take a look at the ClearPass Solution Guide for Wired Policy Enforcement.
| Tim Cappalli | Aruba Security | @timcappalli | timcappalli.me |
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
Thanks Tim,
Just at a high level for my understanding:
Clearpass - switch is added as a device within here and a policy ready for user upon successful 802.1x authentication?
On the switch - valid certificate from our CA and some config to perform checks for each port?
Can I disable the checks on certain ports?
Can I have multiple certificates on my switch to account for people with different CA certs?
The switch is not involved in the EAP transaction beyond encapsulating it into a RADIUS request.
Thanks Tim
