Highlighted
Configuring DHCP Server and DHCP Relay in ArubaOS-Switch
Hello All,
Attached guide provides in-depth understanding about DHCP Server and DHCP Relay Implementation in ArubaOS-Switch with configuration examples.
For more information about DHCP Relay, please, visit the following link: http://h22208.www2.hpe.com/eginfolib/networking/docs/switches/RA/15-18/5998-8165_ra_2620_mrg/content/ch03s09.html
Thank You,
Priyank Patel
Highlighted
Re: Configuring DHCP Server and DHCP Relay in ArubaOS-Switch
Hi Priyank,
thank you for the complete information.
One thing is missing for me : "How is the source address choosen?"
The szenario is that you have multiple IP adresses in one VLAN of the routing switch and want to move from a local DHCP server to a central one with DHCP Relay. And for only one address range you provide the addresses via DHCP.
Is there a command to see the "primary" address of the VLAN and one to set one address as the primary address?
I know at least two szenarios where I came across this issue.
Hendrik
Highlighted
I have DHCP configured on a linux server and the core switch which has layer 3 interfaces have the the ip helper-addresses configured pointing to the Linux DHCP server..do i still need "dhcp-relay" command on the switch for DHCP to work?
Please clarify
Highlighted
Hi Priyank,
Our company recently purchased several Aruba 2930F switches and would like to utilize them in our five offices which are each in a differnet city. We want to configure the switches to use DHCP to provide IP addresses on each of our five different subnets. We currently use Windows Server 2008 DHCP service to provide the addresses.
Windows DHCP servers also have to be authorized on the domain. How is this accomplished at the command line for the 2930F.
Also, if there a prescribed order that the commands need to be entered.
The Windows DHCP servers provide the following information to our clients.
IP address assignment from a defined range of addresses in our DHCP pool
Lease duration when lease is granted   Ex. 8 days
Default router address
IP Address of DNS servers
DNS domain name
Lease reservations for some devices
Could you please explain how this same configuration would be applied from the 2930F command line as these configuration options are not provided in the web based GUI.
Thank you for any assistance/guidance you may be able to provide.
