Contributor II
Re: Converting SFPs from stacking to uplink in 2500
 It is strange that disabling STP brings down the link. STP doesn't control physical link/port properties.
Now, With ports connected on S1500 with Corinex, and STP enabled (spanning-tree mode mstp),
Can you dump the o/p of  "show interface gigabitethernet <x/y/z>" for ports on both S1500s ?
And, when you say  "When I connect them to any 2 switches they work fine"
 - which switches are you refering to ?
Also, to confirm the connectivity, is this how they are connected ?
S1500-ONE {GE-0/0/1} --------- [Corinex adapter]------------ {GE-0/0/1} S1500-TWO
-Vinay
Contributor I
The link was done due to another issue
But when I convert it to PVST, everthing worked
But do we have a way to keep the MSTP and unblock the traffic
Contributor II
As we know PVST runs seperate STP instances per VLAN, whch makes some ports in "Forward" state in some VLANs & blocking in others, hence we can achieve kind of load-balancing of traffic
 Similar thing can be achieved in MSTP as-well.
 By default when you enable MSTP, only one 'instance' is running which spans on VLANS on the system.
  For better load-balancing of traffic, you can create multiple MST "instances": via something called as "instance VLAN mapping"
  This needs bit planning & deciding a root-bridge for each of those instances for "optimal" topology.
Sample config like below needs to  be configured on all the switches in your topology
(IDF-1) (config) #mstp
(IDF-1) (Global MSTP) #region-name REG-1
(IDF-1) (Global MSTP) #instance 0 bridge-priority 16384
(IDF-1) (Global MSTP) #instance 1 bridge-priority 32768
(IDF-1) (Global MSTP) #instance 2 bridge-priority 16384
(IDF-1) (Global MSTP) #instance 1 vlan 100,200
(IDF-1) (Global MSTP) #instance 2 vlan 300,400
  Above config makes VLAN 100,200 as part of MSTP "instance 1", and so on....
  And bridge-priority needs to be varied on other switches. In short, Bridge-priority (lower) decides which switch will be root-bridge for specific instance, (Refer MAS documentation for more details...)
