Q:
What is the default MTU size on Aruba HPE Switches and how to validate the same?
Unlike Mobility Access Switches, who's MTU size is 1514 bytes by default, Aruba HPE Switch has a default MTU size of 1500 bytes only. To verify the MTU size on Aruba HPE Switch, collect "show tech all" and look for "ghsNetStatShow". This will show the MTU size for all the VLAN interface. There are no CLI commands available to increase/modify default MTU size on Aruba HPE Switch, but jumbo frames can be enabled on respective VLAN, if packet size are found to be exceeding 1500 bytes.
Aruba HPE Switches:
ghsNetStatShow Destination Gw Iface mtu hops ttl flags ---------------------------------------------------------- 10.16.0.0/16 * vl2 1500 0 INF U C 10.20.0.0/16 * vl5 1500 0 INF U C
Mobility Access Switches:
(ArubaS2500-24P) #show interface 0/0/0 GE0/0/0 ------- GE0/0/0 is administratively Up, Link is Down, Line protocol is Down Hardware is Gigabit Ethernet, Interface is GE0/0/0, Address is 00:1a:1e:09:c5:42 Encapsulation ARPA, Loopback not set Configured: duplex (Auto), Speed (Auto), FC (Off), Autoneg (On) Auto negotiation in progress Interface index: 1 MTU 1514 bytes Link flaps: 0 Flags: Access, Trusted Link status last changed: 0d 00:00:00 ago Last update of counters: 0d 00:00:00 ago Last clearing of counters: 0d 00:00:00 ago
