Does Aruba 8320 Switch Series is supported multi vendors NAC like:
Thanks you!
You generally don't use NAC on a core or aggregation switch.
Is this required for a tender?
Like Tim says: port-access is not common on a core, but the switch does supports radius and tacacs for management. please also see:
https://www.arubanetworks.com/assets/ds/DS_8320Series.pdf
