Re: Does Aruba switch have motd banner?
madjali,
Please use the exact banner motd code from my post.  It seems to look fine on the commandline, but scroll bars in the GUI.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Aruba
mathieuc/cjoseph,
I'm sorry I mis-read the comment:
"I don't see it on the GUI login screen though. If I remember when I did my test without the quote I saw it but not now with the quote..."
I thought you were saying the banner was missing entirely.
After using cjoseph's example I see that we're ignoring the whitespace on the right of each line and requiring scroll bars to see the full text.
Best regards,
Madani
@cjoseph wrote:
mathieuc,
Just use quotes:
banner motd ^
"*     Access to this computer system is restricted to       *"
"*     official use by users authorized by Corp Inc.,        *"
"*     and must comply with the Information Security         *"
"*     policies listed on the Corp Corporate Intranet at:    *"
"*     http://iweb/informationsecurity/documents/            *"
"*     policies/Policy.htm                                   *"
"*     Corp may monitor and disclose information on or       *"
"*     about this system, and you should have no             *"
"*     expectation of privacy in using it.                   *"
"*     Your continued use of the system constitutes          *"
"*     agreement to these terms. If you do not agree,        *"
"*     please disconnect immediately.                        *"
thank you  cjoseph
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
Contributor II
Just an update on this bug. I got a reply from customer support saying that Engineering has fixed the banner alignment issue and display of it in the web UI. The fix will be integrated in next code release early this year.
