Wired Intelligent Edge
Dynamic Segmentation: User Data Retrieval of type 1 for user failed
  • 1.  Dynamic Segmentation: User Data Retrieval of type 1 for user failed
    Posted Oct 08, 2019 11:39 AM
    I've configured a 2930F with local user roles, and the client gets assigned that role fine from ClearPass. With 'show port-access clients' I can see the user is connected to the network with the correct user role. However when I try to enable user-based tunneling, I'm getting these error messages.
    2930F(eth-5)# enable
    2930F(eth-5)#
    I 10/08/19 18:32:12 00435 ports: port 5 is Blocked by AAA
    0012:18:51:21.95 TNT mtnodeUserCtrl:aqLookupSpecify failed: result= -13
    0012:18:51:21.95 TNT mtnodeUserCtrl:User Data Retrieval of type 1 for user b827eb-cb3eea failed
    0012:18:51:21.95 TNT mtnodeUserCtrl:userTNodeProcAddUserReq: UAC FSM failed for USER_TNODE_UAC_START_EVT
    I 10/08/19 18:32:12 00076 ports: port 5 is now on-line
    I 10/08/19 18:32:12 00001 vlan: TUNNELED_NODE_SERVER_RESERVED virtual LAN enabled (11 times in 60 seconds)
    I 10/08/19 18:32:12 00002 vlan: TUNNELED_NODE_SERVER_RESERVED virtual LAN disabled (11 times in 60 seconds)
    And then the result=-13 error just repeats.
    I have configured the secondary user role:
    aaa authorization user-role name "UBT-LUR-Camera"
       policy "camera"
       vlan-id 3308
       tunneled-node-server-redirect secondary-role "UBT-Camera"
    And on the mobility controller I have role UBT-Camera with VLAN 3308 enabled and with allowall ACL.
    Connection to the controllers also seem fine:
    # show tunneled-node-server state
     Local Master Server (LMS) State
     LMS Type     IP Address       State        Capability Role
     Primary   :  10.133.5.61      Complete     Per User   Operational Primary
     Secondary :  10.133.5.62      Complete     Per User   Operational Secondary
    Any tips for troubleshooting this?
    Thanks!
  • 2.  RE: Dynamic Segmentation: User Data Retrieval of type 1 for user failed
    Posted Oct 08, 2019 01:38 PM
    The tunnel is in a completed state with the switch from your output.
    Is VLAN 3308 enabled on the switch?
    Did you enable user roles on the switch?
    aaa authorization user-role enable
    Did you check your radius configuration on switch? Specifically if the RADIUS key is correct.
    Lastly, Did you disable and enable the port?
    int 5
    disable
    enable
    After this what do you see on the output for "show port-access clients"
    What is the output of "show tunneled-node-users down".
  • 3.  RE: Dynamic Segmentation: User Data Retrieval of type 1 for user failed
    Posted Oct 08, 2019 01:45 PM
    I have enabled user roles. (I was following the dynamic segmentation video series from Youtube). If I remove the secondary-role:
     no tunneled-node-server-redirect
    Then enable port I can see:
    Port  Client Name   MAC Address       IP Address      User Role         Type  VLAN
    5     b827ebcb3eea  b827eb-cb3eea     n/a             UBT-LUR-Camera    MAC   3308
    RADIUS is working too and I get the roles etc. But after enablind the redirect I get those error messages (after disabling the port and then enabling it again).
    show port-access client and show tunneled-node-users are empty
    When I followed the videos port-based tunneling worked, so I guess the controller is in somewhat working condition :)
  • 4.  RE: Dynamic Segmentation: User Data Retrieval of type 1 for user failed
    Posted Oct 08, 2019 02:01 PM
    On the switch is the port configured as an access port or a trunk port?
    What is the image version of the controller ?
    On the controller what is the output of "show tunneled-node config" "show tunneled-node-mgr trace-buf" and "show tunneled-node-mgr stats".
    Just to verify is the vlan 3308 in up state in the controller(MD that you are trying to redirect the user-traffic when you use the tunneled-node-server-redirect command)?
  • 5.  RE: Dynamic Segmentation: User Data Retrieval of type 1 for user failed
    Posted Oct 08, 2019 02:09 PM
    It's an access port. Controllers are managed by Mobility Master, running the commands from the MC:
    (i1-mc1) #show tunneled-node state
    Tunneled Node State
    IP  MAC  port  state  vlan  tunnel  inactive-time
    (i1-mc1) #show tunneled-node config
    Tunneled node Server:Enabled
    Tunnel Loop Prevention:Disabled
    (i1-mc1) #show vlan  3308
    VLAN CONFIGURATION
    VLAN   Description  Ports         AAA Profile  Option-82
    3308   VLAN3308     GE0/0/0-0/1   N/A          Disabled
    (i1-mc1) #show interface gigabitethernet 0/0/1 trusted-vlan
    Trusted Vlan(s)
    3308
    GE 0/0/1 is up, line protocol is up
    gi0/0/1 is the uplink trunk port towards the rest of the network. Controllers are 8.4.0.4 and switch 16.09
  • 6.  RE: Dynamic Segmentation: User Data Retrieval of type 1 for user failed
    Posted Oct 08, 2019 02:52 PM
    Each tunneled-node client uses one AP license.
    What is the output of show license-usage ap
    Please refer this document to configure.
    https://www.arubanetworks.com/techdocs/ArubaOS_81_Web_Help/Content/ArubaFrameStyles/Mux_config/Configuring_a_Wired_Tunn.htm
  • 7.  RE: Dynamic Segmentation: User Data Retrieval of type 1 for user failed
    Posted Oct 08, 2019 02:54 PM
    (i1-mc1) #show license-usage ap
    AP Licenses
    Type                      Number
    AP Licenses               16
    PEF Licenses              16
    MM Licenses               16
    Controller License        True
    Overall AP License Limit  16
    AP Usage
    Type             Count
    Active CAPs      0
    Active RAPs      0
    Remote-node APs  0
    Active MUX       0
    Active PUTN      1
    Total APs        1
    Remaining AP Capacity
    Type  Number
    CAPs  15
    RAPs  15
    I believe I have everything configured that's in the link?
  • 8.  RE: Dynamic Segmentation: User Data Retrieval of type 1 for user failed
    Posted Oct 08, 2019 03:06 PM
    The PUTN is using one license so you are good on the license front.
    What do you see in the logs for this user?
    Show log security 50
    Show log user 50
    I believe the user is wired, whats the scenario when you use a wireless user with the tunneled-node redirect command enabled?
  • 9.  RE: Dynamic Segmentation: User Data Retrieval of type 1 for user failed
    Posted Oct 08, 2019 03:11 PM
    Log's have only row about my admin login, but nothing related to the tunneled node (I tried disabling and then enabling the port).
    Not really sure about the second part though... tunneled node is for wired users not wireless and the redirect is configured in the 2930F switch.
  • 10.  RE: Dynamic Segmentation: User Data Retrieval of type 1 for user failed
    Posted Oct 08, 2019 03:50 PM
    Ah yes, my bad. Was asking my routine wired users TShoot questions :D
    The configuration looks legit. The only thing that comes to my mind is the GRE tunnel.
    Is GRE Traffic allowed ?
    The switch establishes a user GRE tunnel when you add the redirect command.
    When the attribute "UBT-LUR-Camera" in matched in clearpass, then clearpass redirects this user over the GRE tunnel to MD.
    The UBT-Camera (secondary role) should be mentioned in this redirect message.
    What are you seeing wrt clearpass redirect message?
  • 11.  RE: Dynamic Segmentation: User Data Retrieval of type 1 for user failed
    Posted Oct 08, 2019 04:01 PM
    I have that secondary role configured on the 2930F, so ClearPass doesn't need to return that. Just the primary role. On the switch I have
       policy "allowall"
       vlan-id 3308
    and that UBT-Camera exists on the MC. Clearpass doesn't do any matching based on those roles or redirecting. It checks the user account and then sends back:
    Radius:Hewlett-Packard-Enterprise:HPE-User-Role	= UBT-LUR-Camera
    this works as you can see from my second post.
    As port based tunneling worked like I wrote, GRE is allowed to the MC and back.
  • 12.  RE: Dynamic Segmentation: User Data Retrieval of type 1 for user failed
    Posted Oct 08, 2019 04:11 PM
    Well PPTN works like you've mentioned. Its the PUTN that is not working when the redirect command is set.
    I think a switch only supports either one at any given time AFAIK.
    Have you tried creating an new unused VLAN and using that VLAN for PUTN?
    What ACLs are there in the default-tunneled-user AAA profile?
    Have a TAC ticket opened in parallel to this post as well.
  • 13.  RE: Dynamic Segmentation: User Data Retrieval of type 1 for user failed
    Posted Oct 08, 2019 04:18 PM
    Yes the switch only support either port or user based tunneling. I've switched the swtich to user based tunneling with command
    tunneled-node-server mode role-based reserved-vlan 4091
    PPTN doesn't use the secondary roles, you just set the controller IP and then match VLANs on MC and switch and port the port in that VLAN and voilá. With PUTN you need to have the secondary user role, either configured on the switch or push it down from CPPM with downlodable user roles and stuff. I'm just trying to get the first step working without going full CPPM. Which is to configure LUR on 2930F with secondary role.
    Check "Aruba Networks Dynamic Segmentation Inside Out" from Airheads youtube channel for more information. I have my setup configured similarly as the author does in videos 9-10 but seems I'm still missing something.
  • 14.  RE: Dynamic Segmentation: User Data Retrieval of type 1 for user failed
    Posted Oct 08, 2019 04:22 PM
    Was the video using 8.4 as well? as there may be some new caveats (we may miss due to new features being introduced) to configuration to every new version.
    What is the TAC's take on this?
  • 15.  RE: Dynamic Segmentation: User Data Retrieval of type 1 for user failed
    Posted Oct 08, 2019 04:12 PM
    Can you try removing the policy line from the switch user role and see if that works?  Or add in all class/match statements into the user role.  If using a switch policy on the primary user role, it needs to have all class, policy, and match statements included as shown here:
    https://techhub.hpe.com/eginfolib/Aruba/16.09/5200-5908/index.html#GUID-F7DC6844-AF1A-47AA-A85F-2E9E8974523E.html
  • 16.  RE: Dynamic Segmentation: User Data Retrieval of type 1 for user failed
    Posted Oct 08, 2019 04:23 PM
    I tried removing the policy under UBT-LUR-Camera role, but I'm getting the same error message.
    Before that I had the user-role configured like this:
    class ipv4 "alltraffic"
         10 match ip 0.0.0.0 255.255.255.255 0.0.0.0 255.255.255.255
       exit
    policy user "allowall"
         10 class ipv4 "alltraffic" action permit
       exit
       policy "allowall"
       vlan-id 3308
  • 17.  RE: Dynamic Segmentation: User Data Retrieval of type 1 for user failed
    Posted Oct 08, 2019 05:10 PM
    For simplicity I would also remove the vlan-id and policy command from the user role, all you really need is the tunneling command to get the tunnels up.
    Do you get any output when running the command "debug usertn" and "debug destination buffer" (or session) on the switch?
  • 18.  RE: Dynamic Segmentation: User Data Retrieval of type 1 for user failed
    Posted Oct 08, 2019 05:17 PM
    I've attached the debugging output (it's what I had in the original post too)
    In this case I tried with just this config:
       exit
    ClearPass returned (switch requested this 26 six times, CPPM replied with Accpet everytime)
    Output RADIUS Attributes -
    Attachment(s)
    txt
    2930F-debug.txt   8 KB 1 version
  • 19.  RE: Dynamic Segmentation: User Data Retrieval of type 1 for user failed
    Posted Oct 08, 2019 05:20 PM
    Why does it say that your port 5 is blocked by AAA? Is this done intentionally?
  • 20.  RE: Dynamic Segmentation: User Data Retrieval of type 1 for user failed
    Posted Oct 08, 2019 05:37 PM
    Port of course starts in blocked state, because there has not been authentication yet. See for example this debug log without the UBT secondary role where I just get the LUR info from CPPM:
    2930F-alempi(eth-5)# enable
    I 10/09/19 00:33:10 00435 ports: port 5 is Blocked by AAA
    I 10/09/19 00:33:11 00076 ports: port 5 is now on-line
    I 10/09/19 00:33:11 00001 vlan: VLAN3308 virtual LAN enabled (25 times in 60
                seconds)
    2930F-alempi(eth-5)# show port-access client
     Port Access Client Status
    You should lab this dynamic segmentation setup yourself too so we wouldn't have to ge through each and every step :) Appreciate the help still.
  • 21.  RE: Dynamic Segmentation: User Data Retrieval of type 1 for user failed
    Posted Oct 08, 2019 05:41 PM
    On my to-do list now.Gonna try it this weekend. :P
  • 22.  RE: Dynamic Segmentation: User Data Retrieval of type 1 for user failed
    Posted Oct 08, 2019 07:42 PM
    Can you post the entire show tunneled-node-server state command?  Are the controllers showing up as UACs?
    Do you have enough resources in "show policy resources"?
    I'm checking internally to find out what that output means specifically.
  • 23.  RE: Dynamic Segmentation: User Data Retrieval of type 1 for user failed
    Posted Oct 09, 2019 01:25 AM
    2930F-alempi# show tunneled-node-server state
     Switch Anchor Controller (SAC) State
                   IP Address       Mac Address             State
     SAC         : 10.133.5.61      204c03-0aaef0           Registered
     Standby-SAC : 10.133.5.62      204c03-269a0c           Registered
     User Anchor Controller (UAC) : 10.133.5.62
     User              Port       VLAN       State       Bucket ID
     User Anchor Controller (UAC) : 10.133.5.61
    Attachment(s)
    txt
    policyresources.txt   4 KB 1 version
  • 24.  RE: Dynamic Segmentation: User Data Retrieval of type 1 for user failed
    Posted Oct 25, 2019 02:37 PM
    TAC helped with this. We don't have RFP licenses so it was something related to that. They had to disable RFP licenses and enable them again or something along these lines, and it started to work
