Yes, you can. I just created a blog post on the topic!
AOS - Wireshark: remote capture
Hhmmm, misread your post. The blog is to send traffic from the switch to a remote Wireshark instance. However, the remote instance can also be a switch. Use the "mirror endpoint" command on the destination switch to capture the traffic and send it to a specific switch port.
