Wired Intelligent Edge
Hardware and Accessories requirment for VXS configuration and preparation
  • 1.  Hardware and Accessories requirment for VXS configuration and preparation
    Posted Aug 24, 2019 10:04 AM
    Dear All
    Can I have the documentation for Hardware and Accessories requirment for VXS configuration and preparation Hardware and Accessories requirment for VXS configuration and preparation
  • 2.  RE: Hardware and Accessories requirment for VXS configuration and preparation
    MVP GURU
    Posted Aug 24, 2019 01:32 PM
    What is VXS?
  • 3.  RE: Hardware and Accessories requirment for VXS configuration and preparation
    Posted Aug 24, 2019 09:11 PM
    Sorry for the typo is VSX (Virtual Switching Extension)
  • 4.  RE: Hardware and Accessories requirment for VXS configuration and preparation
    MVP GURU
    Posted Aug 25, 2019 09:43 AM
    Your starting point for a successfull VSX deployment is the ArubaOS-CX Virtual Switching eXtension (VSX) guide for 10.03.
  • 5.  RE: Hardware and Accessories requirment for VXS configuration and preparation
    Posted Aug 25, 2019 10:45 AM
    Hi
    This guide no have mention the hardware accessories requirement.
  • 6.  RE: Hardware and Accessories requirment for VXS configuration and preparation
    MVP GURU
    Posted Aug 25, 2019 10:53 AM
    What do you mean with "hardware accessories requirement"?
    VSX requires you to play with 2 (two) Aruba 8320 OR 2 (two) Aruba 8325 OR 2 (two) Aruba 8400X switches...you can't mix them to form a VSX.
    All the switch above will permit you to select most appropriate interfaces (generally using SFP+, QSFP+ Transceivers or DAC Cables) to setup VSX ISL aggregated link and VSX ISL Keepalive link (SFP Transceiver(s) will suffice)...there is not a universal BoM Bill of Material to create a VSX deployment...it is all dependant by YOUR SCENARIO/TOPOLOGY and YOUR SPECIFIC REQUIREMENTS/RESTRICTIONS/BUDGET.
