1920S MAC and 802.1x Authtication with Auto detect - The requirement is for the switch to auto-detect 802.1x or macAuthentication
There are two options in the Authticator option Control mode settings in 1920S WeB GUI.
MAC based is also used for the pc attached to phone use case
As per the below Goto -> Authticator option and then Select Control Mode -> MAC based, By default the control mode is set to AUTO
Attach the phone and the PC to the port where the Control mode setting is configured as MAC BASED, it will auto detect and authenticate both phone and the PC.
If the control mode setting is set to AUTO then only the client with 801.x will authenticate.
