We have users requesting for SNMP OID values for CPU on the Halon switches.
Multiple request have come across from customer to monitor their switch via SNMP NMS
Solution:This is the SNMP MIB for the CPU utilisation.
Note that it has 8 entries because the 8400 consists of 8 cores and the Utilisation is given for each of the cores.
# snmpwalk -v 2c -c public 127.0.0.1 .1.3.6.1.2.1.25.3.3.1.2
HOST-RESOURCES-MIB::hrProcessorLoad.196608 = INTEGER: 15
HOST-RESOURCES-MIB::hrProcessorLoad.196609 = INTEGER: 12
HOST-RESOURCES-MIB::hrProcessorLoad.196610 = INTEGER: 18
HOST-RESOURCES-MIB::hrProcessorLoad.196611 = INTEGER: 16
HOST-RESOURCES-MIB::hrProcessorLoad.196612 = INTEGER: 14
HOST-RESOURCES-MIB::hrProcessorLoad.196613 = INTEGER: 18
HOST-RESOURCES-MIB::hrProcessorLoad.196614 = INTEGER: 12
HOST-RESOURCES-MIB::hrProcessorLoad.196615 = INTEGER: 13
Configuration:This is the SNMP MIB for the CPU utilization.
Note that it has 8 entries because the 8400 consists of 8 cores and the Utilization is given for each of the cores.
How do we know which of the CPU is which?
As you can see 196608-196615 are the 8 CPU cores listed in order and the hrPRocessorLoad gives the utilisation for each of these.
# snmpwalk -v 2c -c public 127.0.0.1 .1.3.6.1.2.1.25.3.2.1.3
HOST-RESOURCES-MIB::hrDeviceDescr.196608 = STRING: GenuineIntel: Intel(R) Xeon(R) CPU D-1527 @ 2.20GHz
HOST-RESOURCES-MIB::hrDeviceDescr.196609 = STRING: GenuineIntel: Intel(R) Xeon(R) CPU D-1527 @ 2.20GHz
HOST-RESOURCES-MIB::hrDeviceDescr.196610 = STRING: GenuineIntel: Intel(R) Xeon(R) CPU D-1527 @ 2.20GHz
HOST-RESOURCES-MIB::hrDeviceDescr.196611 = STRING: GenuineIntel: Intel(R) Xeon(R) CPU D-1527 @ 2.20GHz
HOST-RESOURCES-MIB::hrDeviceDescr.196612 = STRING: GenuineIntel: Intel(R) Xeon(R) CPU D-1527 @ 2.20GHz
HOST-RESOURCES-MIB::hrDeviceDescr.196613 = STRING: GenuineIntel: Intel(R) Xeon(R) CPU D-1527 @ 2.20GHz
HOST-RESOURCES-MIB::hrDeviceDescr.196614 = STRING: GenuineIntel: Intel(R) Xeon(R) CPU D-1527 @ 2.20GHz
HOST-RESOURCES-MIB::hrDeviceDescr.196615 = STRING: GenuineIntel: Intel(R) Xeon(R) CPU D-1527 @ 2.20GHz
Verification# snmpwalk -v 2c -c public 127.0.0.1 .1.3.6.1.2.1.25.3.3.1.2
