Aruba
Re: How do you find directly connected Aruba Devices in S2500 switch?
Looking at the "NU-SLC-Campus" configuration again, I realized I missed something...
This is what you have in the configuration.
interface-profile lldp-profile "lldp-factory-initial"
This effectively disabled lldp. It should look like this:
   lldp transmit
   lldp receive
   med enable
I should have caught that earlier, sorry about that. Add those and let me know what you see.
Regular Contributor I
Yes! That made it work. Now I am seeing the results that I would expect, including the connection between the two switch stacks!
Thanks so much for your help on that.
Aruba Devices in S2500 switch with IAP
Hi ,
i want to configure IAP with mutiple ssid with multiple vlan.
Vlan 1 -management VLAN   192.168.1.0/24
Vlan 2 - Employee ssid    192.168.2.0/24
VLAN 3 -Employee-Mobile SSID  192.168.3.0/24
what settup i need to do in switch and  which port i can connect IAP should be in trunport or access port.
please wright the command in for aruba switch .
Regards
N.Muthu
Re: Aruba Devices in S2500 switch with IAP
The instant AP needs to be on a trunk port on your switch.  The "untagged" or native VLAN should be 1 and VLANs 2 and 3 should be "tagged" or trunked on your switch.  On an Aruba switch, to create a trunk, you need to create a switching profile and assign it to the interface that your access point will be on:  http://www.arubanetworks.com/techdocs/ArubaOS_73_Web_Help/Default.htm#mas_guides/vlans/Creating_and_Applying_a_3.htm
When you configure your SSID for each WLAN on the Instant AP you need to set the VLAN for Static and the Vlan number that you want your users to be on.  For example, your Employee WLAN needs to have "Client IP assignement" set to "Network Assigned",  client vlan assignment of "Static" and a VLAN Number of 2.
On an
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
ArubaOS Consolidated Release Notes
Aruba Technical Webinars
