Wired Intelligent Edge
How to change the Aruba switch password using putty
This thread has been viewed 28 times
  • 1.  How to change the Aruba switch password using putty
    Posted Dec 30, 2019 04:47 AM
    How to change the Aruba switch password using putty?
  • 2.  RE: How to change the Aruba switch password using putty
  • 3.  RE: How to change the Aruba switch password using putty
    Posted Dec 30, 2019 05:09 AM
    Model -  2930f jl262a.
  • 4.  RE: How to change the Aruba switch password using putty
    MVP EXPERT
    Posted Dec 30, 2019 05:10 AM
    This is an ArubaOS switch. Do you know the switch password (i.e need to change it) or have you forgotten it entirely and need to reset it?
  • 5.  RE: How to change the Aruba switch password using putty
    Posted Dec 30, 2019 05:11 AM
    I know the switch password I just need to reset it.
  • 6.  RE: How to change the Aruba switch password using putty
    Posted Dec 30, 2019 05:24 AM
    #password manager user-name xxx plaintext "new password"
    Or
    #password manager plaintext "newpassword"
  • 7.  RE: How to change the Aruba switch password using putty
    Posted Dec 30, 2019 05:31 AM
    Hi Harendra,
    Thanks for your reply.
    I didn't get you. Could you please elaborate.
  • 8.  RE: How to change the Aruba switch password using putty
    Posted Dec 30, 2019 05:41 AM
    Theose are the commands to modify the switch password
    Option 1 for specific user
    Option 2 for default admin
  • 9.  RE: How to change the Aruba switch password using putty
    Posted Dec 30, 2019 05:50 AM
    I am really sorry I don't know much about it. I need your help in changing the password I used that command but I don't know what happened. Can I have your contact number?
  • 10.  RE: How to change the Aruba switch password using putty
    Posted Dec 30, 2019 05:55 AM
  • 11.  RE: How to change the Aruba switch password using putty
    Posted Dec 30, 2019 05:58 AM
    Logout from switch and try login using new password
  • 12.  RE: How to change the Aruba switch password using putty
    Posted Dec 30, 2019 06:06 AM
    I first entered switch username and password and then I typed this command::#password manager user-name xxx plaintext "new password" and after that, it went into user-mode and it is not showing the switch name and unable to logout.
  • 13.  RE: How to change the Aruba switch password using putty
    Posted Dec 30, 2019 06:08 AM
    Send me your whatsapp number
  • 14.  RE: How to change the Aruba switch password using putty
    Posted Dec 30, 2019 06:10 AM
    Thank you!!
  • 15.  RE: How to change the Aruba switch password using putty
    Posted Sep 03, 2021 12:34 PM
    In case someone else runs across this - make sure you are in Config T (configure terminal) mode before you try to run the commands above
    Once connected to the switch:
    Config t
    password manager plaintext <password>
    Will Warsinski
