Wired Intelligent Edge
IP Access-List question (Core Layer 3 to Edge Switch)
  • 1.  IP Access-List question (Core Layer 3 to Edge Switch)
    Posted May 15, 2020 05:38 AM
    Hi Everyone,
    We have a Core Layer 3 'hub' switch (to 'spoke' Edge switches) with several /24 VLANs, a ADDC / DHCP Server 10.17.8.3
    We have recently increased the subnet range:
    To: 10.17.8.0 to 10.17.18.0
    We have the following ACL:
    ip access-list extended "Deny Crosstalk"
    permit ip 0.0.0.0 255.255.255.255 10.17.8.0 0.0.0.255
    deny ip 0.0.0.0 255.255.255.255 10.17.0.0 0.0.255.255 log
    permit ip 0.0.0.0 255.255.255.255 0.0.0.0 255.255.255.255
    exit
    The VLAN below
    vlan 60
    name "Floor 2"
    untagged B4
    ip address 10.17.18.1 255.255.255.0
    ip helper-address 10.17.8.3
    ip access-group "Deny Crosstalk" in
    exit
    On the Edge switch we can ping 'downlinked' Edge switches but not the Core switch 10.17.18.1 interface
    However if we remove ip access-group "Deny Crosstalk" in from VLAN 60 we can ping the Core switch 10.17.18.1 interface
    If we then connect a laptop to the Edge switch it obtains an IP Address and we can ping remote resources but after 3-5 seconds we get:
    General Failure.
    PING transmit failed. General Failure.
    It may have something to do with the subnet mask 0.0.0.255 below.
    If anyone could shed some light on the above that would be greatly appreciated.
    Thanks.
  • 2.  RE: IP Access-List question (Core Layer 3 to Edge Switch)
    MVP GURU
    Posted May 15, 2020 10:48 AM
    Hi! For the sake of simplicity...could you post between </> (thus using the Insert/Edit code sample button above)...the outputs of these two commands below:
    show access-list "Deny Crosstalk"
    show access-list "Deny Crosstalk" config
    You have to consider that an ACL assumes a particular meaning according to where it is applied (I mean: from the point of view of the VLAN interface to which it is applied, for the incoming traffic seen precisely from that interface)...so, as example, the first ACE (permit) rule:
    means that ANY source is permitted to connect to 10.17.8.0/24 using the IP protocol.
    The next ACE (deny) rule:
    means that ANY source is denied to connect to 10.17.0.0/16 (so any host addressed within the range 10.17.0.1 - 10.17.255.254).
    The final ACE (Permit), before the hidden implicit final ANY/ANY Deny:
    means that ANY Source is permitted to connect to ANY Destination (if not previously denied) using the IP protocol.
    Given the above...if you apply this ACE to VLAN 60 what it does to connections incoming FROM VLAN 60 hosts hitting the VLAN 60 interface and with destinations to other VLANs?
  • 3.  RE: IP Access-List question (Core Layer 3 to Edge Switch)
    Posted May 15, 2020 07:22 PM
    Access Control Lists
    Name: Deny Crosstalk
    Type: Extended
    Applied: Yes
    ID action IP Mask proto oper port(s) Log
    1 permit src: 0.0.0.0 255.255.255.255 IP
    dst: 10.17.8.0 0.0.0.255 IP
    2 deny src: 0.0.0.0 255.255.255.255 IP log
    dst: 10.17.0.0 0.0.255.255 IP
    3 permit src: 0.0.0.0 255.255.255.255 IP
    dst: 0.0.0.0 255.255.255.255 IP
    Type: Extended
    Applied: Yes
  • 4.  RE: IP Access-List question (Core Layer 3 to Edge Switch)
    Posted May 16, 2020 07:24 PM
    Hi Parnassus,
    Show ACLs below (without HTML as it gets quarantined for 'moderation')
    Type: Extended
    Applied: Yes
    Type: Extended
    Applied: Yes
