I'm new here and I would need some help,
I have in total 4 Aruba 2930M switches, they are setup in a star with one switch serving as central switch,
I have one vlan for Dante, one for other protocols, and one management vlan.
From this central switch there is one fiber trunk which works fine, the other 2 switches are trunked by copper, in the copper trunk switches it's not possible to ping from one device to another,
this is the running config:
SwitchStage# sh run
Running configuration:
; JL320A Configuration Editor; Created on release #WC.16.07.0003
; Ver #14:01.4f.f8.1d.9b.3f.bf.bb.ef.7c.59.fc.6b.fb.9f.fc.ff.ff.37.ef:02
hostname "SwitchStage"
module 1 type jl320a
trunk 22-24 trk1 lacp
snmp-server community "public" unrestricted
oobm
ip address dhcp-bootp
exit
vlan 1
name "MGMTVLAN"
no untagged 1-20
untagged 21
tagged Trk1
ip address 192.168.10.1 255.255.255.0
ipv6 enable
ipv6 address dhcp full
exit
vlan 2
name "DANTE"
untagged 1-12
tagged Trk1
no ip address
exit
vlan 3
name "OTHER"
untagged 13-20
tagged Trk1
no ip address
exit
spanning-tree Trk1 priority 4
no tftp server
no autorun
no dhcp config-file-update
no dhcp image-file-update
this is the lldp info
SwitchStage# show lldp info remote-device
LLDP Remote Devices Information
LocalPort | ChassisId PortId PortDescr SysName
9 | 3821c7-5d4480 10 10 SwitchPA
12 | 3821c7-5de680 12 12 SwitchKoker
20 | 3821c7-5de680 20 20 SwitchKoker
24 | 8030e0-eba480 48 48 SwitchKleineZaal
As a workaround I have now patched directly one port in the Dante vlan to a Dante port on another switch, this is working ok..
Could you please advice on how to just get all trunks up and running for all vlan, in a star configuration..
Thanks!
